Cam Gear Cover Removal?
Old Sep 27, 2004 | 09:16 PM
EvilBlueEvo8's Avatar
If I just want to take off the cover for swapping it with a carbon fiber one, do I have to jack up the motor and remove the engine mount or can I just undo the 4 10mm bolts and have the cover just slide up? I looked at some how tos for cam or cam gear installation but you have to jack it up for that. Thanks.
Old Sep 27, 2004 | 09:21 PM
lambtron's Avatar
Yeah after you remove those bolts the cover will slide right up. You'll probably have to work it around a little bit, but that's all it takes.
