Stock vs Iridium spark plugs
Old Oct 4, 2004 | 03:28 PM
k270kmh's Avatar
Guys, I would like to know if there is an improvement in performance changing the stock platinum heat range 7 to the Iridium heat range 7.
I did not mention 8 because my car is almost stock.
I bought the Ralliart RAY6601 spark plugs, it will be with me in a few weeks.
Old Oct 4, 2004 | 06:14 PM
TampaTurbo's Avatar
the stock plugs should already be iridium6s, I just put in iridium 7s
Old Oct 4, 2004 | 07:54 PM
SuperHatch's Avatar
TampaTurbo is correct, the stock plugs are iridiums.
- Steve
Old Oct 5, 2004 | 06:35 PM
k270kmh's Avatar
Do you know the stock spark plug heat range? I thought that was 7!
BTW, Someone here know the difference between the stock and Ralliart RAY6601 spark plugs?
What are the advantages and disadvantages of going one step colder?
Thanks
Old Oct 5, 2004 | 06:42 PM
mitsuorder's Avatar
the stock plugs are NGK Iridium heat range 7, from what I remember the Ralliarts are NGK, yep just found them here http://www.poweraxel.com/ralliart/ca...e/evo8/c4.html If you really want them tell me, I have a contact that can get us anything listed on the Ralliart website.
Old Oct 5, 2004 | 07:58 PM
Nad1370's Avatar
Thanks
Advantage............can handle more boost without blowing out
Disadvantage........More likely to foul out than the stockers on regular driving.
Old Jan 8, 2007 | 07:35 PM
AlexEvo's Avatar
something to chew on for you guys, i talked to the dealer and was told that even the factory plugs they use are NGK Iridiums. does this mean they use the BKR7EIX? or perhaps some one-off one that NGK specifically makes as OEM for mitsubishi when it comes to Evos?
Old Jan 8, 2007 | 07:40 PM
evodan2008's Avatar
what is the best spark plug for are car or any high boost car. price not being an issue. i would spend 20.00 a plug if it was the best. so what realy is the best spark plug for a high h/p car???
Old Jan 8, 2007 | 07:42 PM
Mivecless's Avatar
I have seen the standard copper plugs pick up 10-12whp OVER the iridiums actually.
Old Jan 8, 2007 | 07:53 PM
jroller's Avatar
Id really be interested in seeing this horespower gains over iridiums can you post a link to the article or dyno number?
Old Jan 10, 2007 | 10:19 AM
AutobonEvo's Avatar
yeah i was also wondering what plugs i should go with. I have about 333 HP suggestions please!
Old Jan 10, 2007 | 10:35 AM
mitsuorder's Avatar
ngk BR8EIX plugs are excellent and provide a bit more of a safegaurd by being non protruding in the case of detonation. They are also very effective in helping with problematic p0300 cars.
Old Jan 10, 2007 | 11:12 AM
joeymia's Avatar
yeah ok...
Old Jan 10, 2007 | 11:40 AM
Ev0ikon's Avatar
Copper Plugs Does make a bit more power on my car as proven by my butt dyno :P
Hut if you are the lazy type, stick with Iridium stock range which is SEVEN. And stock plugs aer Iridium. Don't ever put the junky Platinum on our car.
Old Jan 10, 2007 | 02:45 PM
jroller's Avatar
Talked to Todd from from Trick Flow Racing (who used my SC Mustang to prototype an exhaust system). He said that on all the forced induction engines they have engine dynoed, he has never seen a decrease in power when going from a standard plug to Iridiums. He said they dont seem to suffer "spark blowout" as easy as a non Iridiums. He also stated no advantage in an N/A engine.
Ralliheart
Dec 3, 2015 08:03 AM
brakeboost980
26
Apr 3, 2015 02:17 AM
pinoy6969
Pacific Northwest
Jul 27, 2012 12:53 PM
EvilBlueEvo8
Oct 19, 2004 06:02 AM
4G63>OOOO
29
Aug 16, 2004 06:30 PM
