Those with HKS RS Intake and NO problems
Originally Posted by Toddevo 8
You will gain no Hp. I did this on a dyno with no gian. stay with the stock air box.
Originally Posted by sleet
Mine was pretty easy aswell, the only hard part was to get the god damn clamp off the turbo and the stock maf pipe. Other than that its perfect, no stalling or CEL lights. How often do you guys change your filters tho and where'd you order the extra ones?
Also be careful when removing the 10mm nuts that hold the MAF to the airbox. That whole piece is made of recyled paper / plastic material and easily fractured. The stud has an oval head on it to keep it from spinning and mine broke off part of the airbox when removing the last nut.
Also maybe I would get away from the car or close the hood when unbolting the MAF deal. When mine broke it actually ended up about 6 feet away, not good if it goes in the wrong hole!
Good luck!
Originally Posted by 96_LXR
Dude that is funny . . . AND TRUE! I'm sure they install that turbo inlet clamp when the motor is dangling around on a hoist, once it's in the engine bay it's a real stinker to get to.
Good luck!
Good luck!
i ripped mine apart too!!!
good point
There are several people who have already proved you wrong, so please enlighten us...
how long did it take u guys to do the install on ur RS intakes?
After i get outta work, and I gotta go somewhere an hour after that so i'm debating whether I should be able to do it in an hour or not, otherwise i'll have to wait another week cz I won't get time lol..
what about the low end loss i read so much about? how many of you guys that have had NO problems got flashed or some other form of ecu management afterwards? can you bolt this on and have no problems?
ecu is being sent to dynoflash next week... al assures me that once i put the reflashed ecu in all problems will be solved with a 20hp gain, we'll see when i get it back...
Originally Posted by mphevo
after i put mine on, the car stalls sometimes if you totally let off the gas... mpg is worse... i threw on espilar cat back and mpg is even worse....
Is the MAF facing the right direction?
Are all your connections tight and unrestricted?
A proper install with this intake does tend to confuse the MAF sensor when it sees an increase in airflow, but resetting it should have solved the problem.
From: driving the 10 second beast in ohio or running lightmods.net
you NEED to get your ecu tuned via reflash or s-afc 2 if you want to see any gains from the intake. Otherwise you prolly will feel a slight gain but will actually have a loss. Also, just use common sense and youwon't break your airbox.
Dave
Dave
Originally Posted by GreedMOTO
Did you reset the ECU when you did the install?
so i just got the hks rs intake and i had a question about changing filters. do you just put the new one in or do you have to dress it with some liquid(i dunno what kind, i just remember reading about it) to help it filter the air better?
You can only test if it makes power on a dyno, and yes, it does, probably because of the free flowing filter. But as soon as it starts sucking in hot air from under the hood while driving, the gains will probably be negated.
