Engine Problems?
Old Oct 8, 2004 | 07:33 AM
nVAevo's Avatar
Exclamation Engine Problems?
I have an 03 evo and last week I was on the highway and went to hit the gas in 5th gear well something weird happened the rpms went up real fast then droped again. Well since then I notice it all the time. It also happens in 3rd and 4th gear when im cruising and decide to hit the gas with out down shifting. Does anyone know what that is or has had the same problem. I dont think it is the clutch feels like the engine.
Old Oct 8, 2004 | 07:40 AM
areet's Avatar
If the rpm's go up, your clutch is slipping. 100% sure it's the clutch.
Old Oct 8, 2004 | 07:43 AM
USP45's Avatar
Yep, if there is a direct connection to the drivetrain (i.e. the clutch is good) then the RPM's cannot rev and then catch again. The connection is broken, and that connection is your clutch. Welcome to the club.........
Old Oct 8, 2004 | 07:46 AM
4Gsixty3's Avatar
time to change the STOCK clutch....!!!
Old Oct 8, 2004 | 07:50 AM
nVAevo's Avatar
F*** s*** heres the question since i have so many mods on my car will the dealer replace it.
Old Oct 8, 2004 | 07:52 AM
F&I-EVO's Avatar
How many miles
Old Oct 8, 2004 | 07:54 AM
nVAevo's Avatar
my car has 19000 miles on it
EVO1320's Avatar
clutch is not under warranty
Old Oct 8, 2004 | 07:55 AM
nVAevo's Avatar
FFFFFFFFFFFFFFFFFFFFFF**************************** ********************** Why not
Old Oct 8, 2004 | 07:56 AM
EVO1320's Avatar
consider normal wear and tear item
Old Oct 8, 2004 | 07:58 AM
nVAevo's Avatar
that is so gay. even the company that made the stock clutch said it was too week. F'in cheap mitsubishi. Alright now that i know i need an after market clutch which one should i get?
Old Oct 8, 2004 | 08:08 AM
2k4EvoVIII's Avatar
Mitsu is not being cheap they are being smart. The whole reason they put restrictors and a cheap clutch is to save the drivetrain. Once you take these restrictions out and add a high performance clutch is where you hear all these reports of broken transfercases.
Now if you were Mitsu would you want to keep replacing transmission and Transfercases or would you want to replace a clutch?
Chris
Old Oct 8, 2004 | 08:10 AM
2k4EvoVIII's Avatar
Oh and as far as a clutch depending on how much HP & Torque you have will depend on what clutch you should get. Really i would tell you to get the ACT Street Disk or the RRM Street Disk. If you go with a 4 Puck or 6 Puck you are asking for trouble. Same with the Twin and Tripple Disks. Dont get me wrong i love the Twin and Tripple disks but if it is not needed you should not get it. The ACT and RRM will not hurt any of your driveline parts.
Chris
Old Oct 8, 2004 | 08:14 AM
nVAevo's Avatar
Im running around 345
Old Oct 8, 2004 | 08:18 AM
2k4EvoVIII's Avatar
You will be fine with the ACT clutch then.
Chris
