Spark plug is jscked up..........
This was going down the track...
with 110 oct. the rest look normal. About 3/4 down the track it was like I didnt have any fuel or something. started back firing and stuff. Im really concerned about this. After I changed the plugs it seemed to run alfot getter but I pulled the plugs after a day from being in and the fourth one was still a little darker.
weird.... mine did the same thing today at the track....i think its the same plugs(NGK BPR7ESS..?) 1st 2 run was ok then on the third run it started back firing at about 10 psi...took em out and it sorta looks like yours...not as bad though...i put the stock ones back in and its fine now..i'm never gonna buy those cheap as ones no more...iridium all the way...
Originally Posted by David@Vishnu
pressure and det get a $10 circuit board componed magnefying glass from Radio Shack and see if there are pits and gouges on the ceramic isolator
Looks to me like a detonation/heat condition, of course once it stopped firing it then got all the soot all over it.
the concussion from a detonation event, combined with a slight lean (high heat) condition is enough to cause that. You'll have to do what david@vishnu suggested, get a magnifying glass and look at the conductor, considering how deformed it appears the conductor might have melted.
Oh, and when you get a chance, if you know someone with a scope, have them scope the inside of the cylinder through the plug hole to look for obvious damage.
No idea what boost levels or tune your running, but you might have to go another step colder on your plug...
Originally Posted by nothere
what concerns me is the gap on cylinder 4, is that an illusion or has the ground strap bent over.
if you have made contact that is not good, read rebuild.
However contact would have both deformed the electrode on the plug, but likely left an imprint on the portion of the electrode that made contact, and it doesnt appear to have made contact.
Like I said in my earlier post, try to find someone with a videoscope to look inside the bore and piston surface and look for any obvious damage from contact.
