Help regarding boost setup
Old Oct 9, 2004 | 09:31 PM
sheriff**'s Avatar
I need help answering a few questions regarding my Evolution7.
Currently im running a 45mm trust/greedy wastegate(external), greedy/trust profec2 spec2 boost controller, trust blowoff valve, HKS induction/3inch exhaust.
I need help setting up the boost controller correctly.
Currently; apart from all of those modifications the car is standard, the spring in the wastegate is good for 14.5 psi (about 100 kpa).
I am wanting to know what the standard boost setting is for an Evolution7 (in psi) so i can change my wastgate accordlingly.
Also how shall i set up the high/low settings on the boost controller? also the gain/set values?
What is a good boost to be running given my circumstances?
Can anyone help me in this matter?
Cheers.
