Stock oil feed line for turbo
Any vendors out there have a replacement oil feed line for the stock turbo? It's the oil line that goes from the oil pan to the bottom of the stock turbo. I believe it is aluminum, with a flex section in it. I installed an aftermarket manifold and the line is too short. About a 1/4 inch too short. A riser/spacer would also work. Thanks.
That line is the oil return line, not the feed line. Check with Forced Performance. They can build you one. They sell all the parts on their website for your to make one yourself if you like.
