Finally 3 1/5 exhaust pics!
Originally Posted by Rez90
unless you are making well over 500 to 600 hp...a 3 inch exaust will flow more than enough.
Originally Posted by ex-honda
3" exhaust would be the max. Anything higher you will loose hella bottom end and gain alot of noise. Looks good though.
Wrong, the best turbo exhaust is no exhaust. Many turbo diesel trucks run 5" exhausts
And many turbo diesel guys swear off 5" systems and stick with 4" ones...
you will GAIN top end
you will GAIN weight
you will LOSE bottom end
you will LOSE midrange
you will LOSE response
If you're building a ***** to the wall drag car, go ahead.
Originally Posted by Aniel
Originally Posted by johnnysixer
Sounds mean Probably too loud for daily purposes for my old bones though
i have installed a couple of different brands of exhaust systems on these cars and this is the quietest cruising around. Also for those guys that think your loosing back pressure think about all the exhaust that has to go through the turbo, thats not a big opening plus its being forced fed anyhow i could go on for ever about that.... Cleanevo- like it says in the begining this is the protoype i wasnt sure if 3.5 would fit up in there.
