Finally 3 1/5 exhaust pics!
Originally Posted by TheGVR4kid
And many turbo diesel guys swear off 5" systems and stick with 4" ones...
you will GAIN top end
you will GAIN weight
you will LOSE bottom end
you will LOSE midrange
you will LOSE response
If you're building a ***** to the wall drag car, go ahead.
Unlike NA cars (Cars with out a turbos) Turbo charged cars do not need any back pressure for TQ. The turbo it self provides enough back pressure for the motor. The best exhaust to have is the largest one you can fit under the car. Most cases 3in is go enough to flow over 400whp on our cars. The Supra guys run 3.5-4 when making in the 800+ hp range.
Is 3.5 over kill for most people ya but it does not hurt TQ or HP.
Eric
Eric
Originally Posted by Zeus
Your reaching now... there are few absolutes when dealing with the internal combustion engine. Physics (your "gas laws" and the such) apply when all the variables are "known". What is "known" is that the automotive world is filled with educated “guesses". Granted, there is the "excepted norm", but nothing is absolute. I could show you crazy things like street cars running ludicrous compression on supercharged, pump gas engines... and even after you tore it down yourself, you'd still call me a liar because it "can't be". So back off with the "what is" and the caps. "Normally" needs to be inserted after your "will" as all of your assertions have been proven wrong at one time or another. However, they are "excepted" theories.
Like I said if you're building full drag car, then you might reap the top end benefits. Obviously you will be launching the car in the 5k+ range and keeping the car in that powerband, your low and middle range won't matter.
The saying "best exhaust is no exhaust with a turbo" is complete bullshlt. You might see a slightly higher peak hp number with minimal exhaust restriction, but you will definately suffer everywhere else. As someone who has been tinkering with 4G63's for 9 years now, and most notibly, drove over 800 miles home from the Shootout one year running an open o2 dump, I can definately say that without a doubt, turbos need an exhaust system.
My car feels much better with this exhaust, in fact my car breaks loose at lower rpms but i think i might as well take it to the dyno and get the questions out our heads. I will try to head to Texas this weekend
Let me chime in here. There is definately a difference in low end torque as far as a 2.5 in. downpipe vs. 3 in. It has been dyno proven you give up low end for high end with a full 3 in system on a car not powerful enough to make up for the loss. Now I am wondering if sticking with a 3 in. downpipe but increasing the flow after the cat or test pipe might yield more favorable results.
Shane
Shane
Originally Posted by TooManyHobbies
You need a bit of back pressure to gain maximum torque (and no the turbo does not provide enough, if it does then your turbo is from the 80's because the back pressure caused by most modern turbos is ridiculously low thanks to the genious at work at garrett and I've seen the test results to prove it) and if you make your exhaust completely free flowing (or very close) then you are gonna lose some of that torque.
You ever wonder why our cars loose boost at high RPM's??? The reason why is due to the backpressure being generated at the turbine housing!!! The backpressure is so high it starts to overcome the wastegate spring. Our turbo is not from the 80's. The small discharge nozzles in the turbine create alot of back pressure. By opening up the exhaust much larger after the turbine housing you alleviate a small percentage of this back pressure, but not much. But the turbine housing does definitely create more than enough back pressure.
I got the 4 year degree and I have had a 4G63 since they came out in 1990. Back from the days of the MDSOG, which stood for Mitsubish Diamond Stars Owners Group. One of the founding members back then, was Mr. David Buschur. He said back then, when 2.5" exhausts were the norm. You can't put on an exhaust too big, as long as you can fit it under the car. I guess he still agrees with that statement, so long ago.. I happen to subscribe to that theory as well.
Brian
I havent forgotten about you guys, i still havent had time to take it to the dyno, all i have done to my car at the moment is better intake, 255 fuel pump, boost controller, hks BOV and the exhaust. I got someone working on a fuel management at the moment so im going to wait until i tune it to take it to the dyno.
AJT im using a little section of 3" on the stock downpipe flange and then it flares out to 3.5 so im still using the stock flex set up.
What happened to the thing called Pressure Differential? The greater the pressure differential from the boosted side to the non boosted side the faster the turbo is going to make boost, the faster the turbo makes boost the quicker you get to your torque. Is this correct?
You are correct.. The pressure differential between the intake manifold pressure and the turbine back pressure creates the low end torque. This is governed moreso by the A/R of the turbine housing than the exhaust behind it. The smaller the A/R housing usually translates into quicker spoolup, but lacks the ultimate flow required for high hp. You can go to a larger A/R housing for more top end but loose bottom end response. It is all a compromise with A/R housings. If your turbine housing was so big, then you might be hurting low end by going to an overly large exhaust, but I dont think I have seen a turbine housing that big on an Evo.
Brian
Rexpeed
EvoX 'For Sale' Exterior Styling
1853
Sep 20, 2019 12:33 AM
YoJeano
Dec 5, 2015 06:43 PM
FS[SouthEast]: Tomei - ams - turbosmart - oem - TurboXs - IHI
YoJeano
Nov 17, 2015 01:53 PM
FS[West]: Evo 8 Bare Block and more!
jonwtf416
Jan 7, 2015 10:33 AM
ProccoEVO
18
Sep 28, 2009 06:34 AM
