how high can you turn up the boost?
Old Oct 16, 2004 | 07:48 AM
02MaximizedVQ's Avatar
Originally Posted by inline4g63
Eclipse is different. YOu can safely push the boost up to 30 psi with no problems for that car.
Umm...no sorry. The Eclipse 4G63 is much weaker than the EVO's 4G63.
Old Oct 16, 2004 | 08:13 AM
SterlingEvo's Avatar
Originally Posted by Derek888
Sorry for the newb question but whats the difference between PSI and bar?
I didn't see that anyone else answered this: It's like inches and centimeters... they measure the same thing but using a different scale. See this chart (and others) for conversion:
http://www.chromatography.co.uk/TECH...r/Pressure.htm
or this tool to convert a specific number (eg. 21.543psi= ???bar):
http://www.centauro-owners.com/articles/psibar.html
Old Oct 16, 2004 | 08:24 AM
patsevo8's Avatar
Don't Slap Him, Punch Him!!!!
Old Oct 16, 2004 | 08:41 AM
jamevo8's Avatar
I had Vishnu tune my evo on Tuner Transformation and my boost peaks at 24 psi and tappers to 22 psi, I also have Exeede, HKS 264/272 cams ,cam gears ,10.5 housing and turbo back exhaust with test pipe. Im making 328 hp at the wheels
Old Oct 16, 2004 | 08:46 AM
One thing too that gives you more room to up the boost is higher octane gas...
Old Oct 16, 2004 | 08:47 AM
blackevoVII's Avatar
They are basically the same thing, just differenet measurements. Its like the metric system and decimel here. One is used throughout the world (SI: International System of Units). People like to use bar because its so close to atmospheric pressure.
easy way to convert bar to psi is
bar x 14.5
and psi to bar
psi / 14.5
here = USA
Old Oct 16, 2004 | 09:00 AM
LostSoul Evo's Avatar
actually its 14.7 psi to 1 bar. but that aint much of a difference
Old Oct 16, 2004 | 09:47 AM
It's like my answer and blackevoVII's answer: The same thing, but slightly different
Old Oct 16, 2004 | 10:07 AM
i meant to quote the guy not you...hah im too lazy
yea 14.7 14.5...blah blah.
Old Oct 16, 2004 | 01:36 PM
DSMotorsport's Avatar
you can run US spec Evo8 up to about 20-21 psi dependant on other mods. It is more dependant on fuel cut, and thus total airflow signal to the ecu than anything else. The stock injectors/fuelpump is more than adequate for all the airflow the stock turbo can deal out in any situation.
Knock signal into the ecu will also have an effect. you can run 21psi on pumpgas with no trouble, but that doesn't mean you are actually making any more power than you would at 19psi becuase of the knock/ignition timing retard.
If you have 3exhaust/intake modifications the total airflow signal to the ecu will be higher becuase the engine is not restricted and can natually flow more. you will be able to run LESS boost before fuel cut happens once you mod the car, although you will be making more power @19psi with mods vs 21psi stock.
put afc or flash into the mix and the fuel cut is not the limiting factor anymore, then it's all about octane/knock/AF ratio tuning to determine what the maximum safe boost is.
Old Oct 16, 2004 | 02:48 PM
Originally Posted by mifesto
you can easily get 340hp with a bone stock... the only question is, how many hours of aggressive driving can you do until you blow your head gasket
Id love to see this no modification 70hp increase method. headgaskets on the evo8 are multilayer metal gaskets. Those are extremely strong, on a DSM they are good to over 600whp. 340 shoudn't budge a stock motor.
Old Oct 16, 2004 | 03:49 PM
justrick's Avatar
im running 25 psi it likes it, but i only do it once a month 4 or 5 runs
i dont think ill push it any harder till i build it
Old Oct 17, 2004 | 12:38 AM
evil8's Avatar
If I were to get a boost controller how high can I turn up the boost without damaging the stock turbo or anything else? Is it even possible to boost up on a bone stock Evo? My friend told me I can turn the boost up and get easily 340hp without any damage to the engine or turbo. Should I just slap him?
Your friend is right about not damaging the engine w/ 340hp but it has to be tuned to run safely and it will take much more than a boost controller to get you that power.
Old Oct 17, 2004 | 01:15 AM
TRDHarrier's Avatar
he probably meant 340 hp at the flywheel
Old Oct 17, 2004 | 04:02 AM
Derek888's Avatar
I think he meant 340hp not whp
