Vacuum at idle, or in neutral (no gear, no load)
Old Oct 15, 2004 | 06:10 PM
93civEJ1's Avatar
Just noticed tonight guys, but on my boost gauge when i give my car part throttle slowly increasing RPM's my vaccum gets less, but as the RPMs are rising my car starts to pull more vacuum. If i have a load on the motor in gear and moving at part throttle increasing RPM slowly there is no vaccuum, but why would my car pull vacuum in non gears part throttle with RPM rising slowly?? Vacuum leak somewhere or what??? maybe its done this all along, Ive just started watching my gauges and stuff more recently.
Old Oct 15, 2004 | 08:22 PM
93civEJ1's Avatar
Old Oct 15, 2004 | 08:36 PM
simevo's Avatar
I believe with no load and at part throttle the wastegate is wide open and the bov is recirculating the air so there isn't any real pressure to the manifold so you'll see vacuum since engine is sucking more air as rpm rises.
Old Oct 16, 2004 | 06:48 AM
93civEJ1's Avatar
kool, thanks, just curious...will someone do like a test or something in their driveway just so i can have a peice of mind with this issue,then i can just focus on my main 1 problem.
Old Oct 16, 2004 | 07:09 AM
Jorge T's Avatar
The cams will lower your vacuum reading at idle~ 15-17 in, once you raise rpms to 1200 your no load vacuum will increase back to 20-22 in. This is how it is on mine w 264/272
Old Oct 17, 2004 | 07:45 AM
93civEJ1's Avatar
Thanks, i was just curious....was suprised no one else noticed this.
Old Oct 17, 2004 | 07:49 AM
GreedMOTO's Avatar
I run a slight vacume at idle and in neutral, but i doubt the accuracy of my boost gauge...it's off by 2psi anyway.
Old Oct 17, 2004 | 07:51 AM
93civEJ1's Avatar
doesnt everyone??? lol
Raceghost
Jun 10, 2016 11:28 PM
LeXcite
Dec 5, 2015 02:33 AM
NoJokeEvo
Oct 14, 2015 07:04 PM
nitz
Jul 4, 2009 09:14 AM
silverEVO8
AEM EMS
May 19, 2004 11:18 PM
