Downpipes
Old Oct 18, 2004 | 09:37 PM
BlueEvo04's Avatar
Downpipes
I've been asking evo crews about the downpipes and still can't decide what brand I should get. I just checked the RS*R downpipe and they're saying I can get engine power by as much as 50hp. Currently, I have Hks 30th cat back and looking for the downpipes but please help me with the downpipes. I would like to get RS*R downpipe since this item is on sale $160.
Old Oct 18, 2004 | 09:56 PM
evo81's Avatar
50 hp from dp=no way.maybe a whole turbo back.RS R seems to be okay
Old Oct 18, 2004 | 10:00 PM
lil'evil_evo's Avatar
Go Helix it's only $215.
JeansandJacks's Avatar
i got the helix with cat delete and wraped the dp in header wrap where it goes under the subframe and above the tie bars. its quiet and it pulls like crazy now all the way to the top of the rev range. i love it.
Old Nov 2, 2004 | 02:18 PM
rcrecevo's Avatar
I have the Apexi 3"downpipe and it fits perfect and comes with heat wrap so heat stays away from the oil pan. Also it doesn't need a seperate support bar like the RNR says you need to get for theirs.I have the HKS 3" exhaust on my car.
Old Nov 2, 2004 | 02:24 PM
mitsuorder's Avatar
bump for Helix, give Cal a call at Grouppe-S
Old Nov 2, 2004 | 08:29 PM
vicbdn's Avatar
THe RSR is cheap if anything, I have it and its OK... Dps are DPs its just a big pipe. THe RSR Does taper a bit... like 1/8 of an in so if you're **** about FULL 3 in DP then don't get it.
Old Nov 2, 2004 | 08:57 PM
EVOTEXAS's Avatar
I have the Megan Racing DP. It was 150 shipped. 3" and does not rub the cross braces. I've been running it for a few thousand miles and it's doing great! Why spend more on name? Contact Speednstylez by PM to order! I have several Megan products and they are all great!!! (and cheap )
Old Nov 2, 2004 | 09:01 PM
Sentinal's Avatar
good advice thanks everyone.
Old Nov 2, 2004 | 09:41 PM
touchmyjagee's Avatar
the espelir dp seems worth it for the money. i think vivid was selling it for 170.
Old Nov 2, 2004 | 09:50 PM
TurboFabie's Avatar
If you where to change to a 3" downpipe from the turbo back on an evo, would your stock ecu maps be sufficient enough to keep the engine from running lean in normal circumstances? Generally speaking.
Old Nov 2, 2004 | 09:52 PM
bluebanana23's Avatar
import tuner dynoed the RSR dp with a -5 in peak power. I have the Megan Racing downpipe (no taper,polished,flexes,cheap,fits nice,clears tie bars) and I love it.
JohnnyTwoThumbs's Avatar
I'm selling my Espelir DP for $125 or $500 w/ Espelir exhaust. 200 miles and 4 days on them. PM if you want 'em
Old Nov 2, 2004 | 10:02 PM
Cash Money's Avatar
stay away from any dp with that flew piping... i've witnessed to many shread for my liking... Helix or Buschur is the way to go...
Old Nov 3, 2004 | 12:13 AM
mitsuorder's Avatar
The only thing I would warn you against as far as the Megan dp is that it does not retain the factory donut gasket, it just uses a flat gasket and I have heard of people having problems getting a good seal with them, maybe they have a new solution for this, I don't know.
