View Poll Results: Does your DP rattle?
Yes
15
38.46%
No
24
61.54%
Voters: 39. You may not vote on this poll
POLL: Does your DP rattle?
Old Oct 20, 2004 | 03:46 PM
snoop's Avatar
I have a Helix DP and it does rattle
When I stop at the light I feel the rattle plus if I turn on the AC I get more rattle which appears to be the result of the DP hitting the subframe.
Attached Thumbnails POLL: Does your DP rattle?-hel_evodp1.jpg
Old Oct 20, 2004 | 04:52 PM
WannaRace's Avatar
Buschur 3", no rattle here..
tokeone's Avatar
i have a 3" buschur
its hitting one of the brace bars underneath it
Old Oct 20, 2004 | 04:53 PM
silverEVO8's Avatar
Hey Snoop, mine used to rattle a good bit but Andrew corrected that problem Most aftermarket exhausts (particularly DPs) are likely to rattle so it takes some work and skill to install them and tweak them. I think you can get it to work fine but you'll have to work at it
Good luck
Old Oct 20, 2004 | 04:54 PM
Alias's Avatar
WORKS ceramic coated DP - No rattles, perfect fit!!!
Rocket's Avatar
3 inch Buschur, no rattle
Old Oct 20, 2004 | 04:55 PM
zupber4930's Avatar
AMS 3" (original, not revised one) no rattle
Old Oct 20, 2004 | 04:56 PM
SurfguruJon311's Avatar
I have the AMS turboback and it rattled a good bit, so I got some kartboy hangers and it eliminated most of it!
Old Oct 20, 2004 | 05:00 PM
Ryno's Avatar
Buschur 3 " dp with Cusco lower arm braces and no rattles.
Old Oct 20, 2004 | 05:06 PM
zupber4930's Avatar
That's odd...I have the 3" turboback...totally no rattle. I had one when I first put it on. Couldn't figure out what it was...posted about it (was at work couldn't touch the car at the time)...no one was able to help. I looked into it further when I got home...turned out it was the heat shield for the cat that is attached to the underside of the chassis from mitsu that was slightly tweaked ratteling on the seam of the highflow cat. One stainless steel screw in it solved everything.
Old Oct 20, 2004 | 05:22 PM
EVOTEXAS's Avatar
My Megan Racing downpipe does not rattle but my Perrin Cat delete taps the heat shield above it because the flanges are so big. I have to snip out a little section from the front part.
Old Oct 20, 2004 | 05:44 PM
lil'evil_evo's Avatar
Nope. I even have the verison 1 and it's fit perfect.
Old Oct 20, 2004 | 05:52 PM
evoracerx's Avatar
The Helix pipe fits perfect, the proble is the hangers may flex a little.
Old Oct 20, 2004 | 05:55 PM
UFO's Avatar
UFO
DC Sports 3" DP and no rattle. It's damn close to the front tie bar but doesn't touch.
Old Oct 20, 2004 | 06:09 PM
JFawns's Avatar
Vishnu Standard w/ O2 housing....no rattle.
