Rear O2 sensor failure
Old Oct 23, 2004 | 04:19 PM
EVOFQ300's Avatar
I tried a search and did not find anything. After numerous attempts to get rid of the SES light from running a test pipe. I can only conclude that the sensor is bad. My question is where can I get a replacement sensor for a fraction of the cost that the dealers want to charge?. will any other sensors work ? or does it have to be OEM? . I mean can I go to Pep Boys and buy one from say an Eclipse. I noticed when I was underneath looking at it if you remove the rubber grommet and pull the slack out of the sensor it looks like a plug and play. Meaning a simple replacement job that even I could do . I think pep boys had a bosch for $98.
My primary O2 sensor failed once already which makes me think this is the same, replaced under warranty by the way. I have an apointment on Tues at the dealer to look at it. But this is really my fault for extending the wiring and so I can't really complain if they don't fix it. By the way I have the UR 3" test pipe and the antifouler things installed. Anyone else have a problem with this ? Thanks
Old Oct 23, 2004 | 05:20 PM
BuLocal's Avatar
How many of the antifouler spacers do you have installed? One didn't work for me, I needed two. The first one drilled out 1/2" and the second as it came, NOT drilled out.
Old Oct 23, 2004 | 05:28 PM
Evilution VIII's Avatar
Originally Posted by EVOFQ300
I. I mean can I go to Pep Boys and buy one from say an Eclipse. I noticed when I was underneath looking at it if you remove the rubber grommet and pull the slack out of the sensor it looks like a plug and play. Meaning a simple replacement job that even I could do . I think pep boys had a bosch for $98.
you can get universal bosch sensors from auto parts stores... just as good they just dont have the connector attached have to do it your self... not hard, i would just reccomend soldering the connections also with the kit they give you.
Kyle M.
Old Oct 23, 2004 | 05:39 PM
EVOFQ300's Avatar
I have 2 foulers installed along with the test pipe. If you buy the universal how do you know which is which.as far as the sensor is concerned. I really would like to get plug and play if possible
Old Oct 24, 2004 | 06:27 AM
jimmyv65's Avatar
Universal O2 sensors are "plug and play" Most 02 sensors are not vehicle specific. There are just a few models that are shared over all platforms--Ford, Chevy, GM, Honda, Mitsu, etc..... 02 sensor--It just gives values back to the computer that uses those values in it's calculations. Any parts store will guide you to the correct replacement.
Moreover, you may want to re-think your theory that the sensor is bad. Test your current sensor by putting the cat back in.
Good Luck!
Old Oct 24, 2004 | 06:31 AM
sr20det91's Avatar
Have you tried Bushurs CEL eliminator. It worked for me.
Old Oct 24, 2004 | 06:42 AM
Toddevo 8's Avatar
are you still stock or do you have a aem or utec. exede?? IF so you want need the rear o2.
Old Oct 24, 2004 | 02:01 PM
EVOFQ300's Avatar
Good Luck!
So if I got to autozone or where ever I should be able to get a plug and play?. I think I saw somewhere an OEM sensor was like $250. I will put an AEM in B4 I pay even close to that for a sensor
Old Oct 28, 2004 | 08:50 AM
EVOFQ300's Avatar
Mitsu part number is MR578532. retail $330 or $250 dealer cost. Will the one for an eclipse 2G work?
1fast97gsx
Sep 17, 2013 07:14 PM
chrisw
May 18, 2010 07:51 AM
mf doom
16
Jun 14, 2008 08:35 PM
evilevo22
Oct 3, 2007 02:36 PM
pumpdog720
Aug 12, 2003 04:59 PM
