Weird Problem
Coilpacks can absorb heat and if there is something wrong with them, they could fail when they get hot.. But you pulled codes for:
MAF
Coolant
front o2
IAT
CAS
Coil 1-6
coil 2-5
egr
vss
That is basically every relevant component on the engine..
OHHH! Another thought now that you said its a VR4 (Likely running a OBD1 ECU similar to the 1G Eclipse), Remove the ECU from the car, earlier DSM ECU's had a problem with capacitors that could leak and corrode, and would likely cause the symptoms your describing.. Its the only thing I can think of besides a problem with the wiring harness that can cause all those codes to trigger simultaneously!
MAF
Coolant
front o2
IAT
CAS
Coil 1-6
coil 2-5
egr
vss
MAF
Coolant
front o2
IAT
CAS
Coil 1-6
coil 2-5
egr
vss
MAF
Coolant
front o2
IAT
CAS
Coil 1-6
coil 2-5
egr
vss
The other option is to buy a remanufactured one. They swap out easily.
Hey guys!
Thanks for the replies as always.
I did do the Capacitors. They were replaced with Rubicon capacitors. Mine were leaking, but it wasn't leaking that bad at all. It just started.
But I did swap my ECU out with a good one though.
I took my friend's ECU, put it in my car, start it up (the car was already running prior taking out of my ECU, so my car was already warm), and the CEL was still on (remember, the car is already hot from already running).
How long was I suppose to let HIS ECU run on the car?
I started it, let it idle for a couple minutes, shut it off, and concluded it wasn't a bad ECU.
Trung
Trung
MAF
Coolant
front o2
IAT
CAS
Coil 1-6
coil 2-5
egr
vss
Those are the codes.
MAF (swapped with a good one, and CEL was still on), O2 (just replaced) , Coolant (well, it's coolant..lol), VSS (nah), IAT (not MAF, so not this?) are all the ones I don't think is responsible.
so it's CAS, the two coils, and EGR.
Trung
Coolant
front o2
IAT
CAS
Coil 1-6
coil 2-5
egr
vss
Trung
Try the coils. Tadashi at Technosquare mentioned when I had my car that spark was weak in the car, but everytime he saw someone change them out from anything but stock, it messed up the ECU. He said the electrical is very finicky in that car.
I don't know if he's back from Japan yet (he's been Ill), but Danny might be able to help you;
(310) 787-0847
Also, Matt Monet at Dynamic Racing http://www.dynamicracing.com/customer/home.php
Mike Mahaffy at Altered Atmosphere http://www.alteredatmosphere.com/
Brian LaFuente at GT-Pro 626-839-7767
or here http://www.stealth316.com/1-links-t.htm
(310) 787-0847
Yes, I had a VR4 running 15G's w/ HKS boost controller, RPS clutch and Tadashi dialed in rom flashes for me. I had an ECU problem and replaced it. I remember asking him about playing with the coils/spark and he told me all attempts he saw caused ECU problems and not to do it. It ran mid 12's because I didn't track it much but it trapped 115 mph. I sold the car
That being said and going on a 2 and half year old memory, I'd say go stock w/ the coils and speak with Danny. He'll point you in the right direction.
I like those seats. The car had a great interior.
yes, yes they are nice cars indeed. I ordered a set of Berg Bowman? Coils for my car.
What's the brand? and are they good?
Trung
If this doesn't fix it, I am going to install my EGR block off plates, and if that doesn't fix it, it goes to the shop.
I will call denny!
Thanks!!
Trung
Trung
I will call denny!
Thanks!!
Trung
Originally Posted by GREDDY
Stock coils and pluggs and stock gapping.
