Weird Problem
Old Oct 28, 2004 | 11:51 PM
  #46
Sirius_GTO's Avatar
the brand for the coilpack i bought is Berg Warner.
Is that any good. I can't afford OEM guys
it's 90 bucks as it is from Oreilys.
I do have stock plugs, however they are gapped at .035.
Thanks,
Trung
I will call danny tomorrow.
Old Oct 29, 2004 | 10:20 AM
  #47
J8dailo's Avatar
my evo was doing that..i took it back to the manufacture for it to be looked at...they said its something wrong with the gasoline i been using...it required premium..and i used premium everytime...after than..i was told to switch gas stations...i use Marathon to fill up my tank...the problem went away...
Old Oct 29, 2004 | 10:41 AM
  #48
Sirius_GTO's Avatar
I know, it's weird.
When I put in the 93 Octane (nonethanol) from IL, that's when the problem started (well, about 1.4 hours later of driving on the highway).
I've only been using iowa gas (92 ethanol).
But the problem is still there.
I'm doing to do the coils and see if that helps.
Thanks,
Trung
Old Oct 29, 2004 | 10:46 AM
  #49
MalibuJack's Avatar
Thanks,
Trung
.035 gap is ok.. Pretty typical gap for a stock coil'ed turbo car.. Although defective or malfunctioning ignitors can cause all sorts of problems, I'm really surprised it would cause THAT much issue.
However, Borg Warner coils are OEM for that car, so you should be ok.
Still, check your bulkhead connector, wiring harness connections from the ECU (make sure all the pins are seated) same for the engine cluster harness (the one that all the sensors connect to)
Anyway, I can't disagree with the coil theory.. When you have defective coils that use ignitors, there can be a "Feedback" of sorts into the ECU which can wreak havoc on its ability to function correctly.. So it makes sense to replace them (if their original parts that came with the car, it makes even more sense..)
Old Oct 29, 2004 | 11:01 AM
  #50
MalibuJack's Avatar
BTW, is your stock ECU 3 connectors or 4? I'm assuming a first Gen ECU which is 3..
Old Oct 29, 2004 | 01:01 PM
  #51
Sirius_GTO's Avatar
You are a smart man, Malibu.
It's a 3 connector-type ECU.
Borg Warner makes the EXACT SAME coils for a 3000GT?
Or is it just OEM Spec?
I just need to make sure, because I was told that I shouldn't alter the coil unless OEM.
Thanks,
Trung
Old Oct 29, 2004 | 02:14 PM
  #52
Sirius_GTO's Avatar
Oreily wanted 93 bucks for EACH COIL (the Borg Warner)?!
I can't afford that ****.
Trung
Old Oct 29, 2004 | 02:19 PM
  #53
MalibuJack's Avatar
Well, check Ebay, see if you can find a set of coils.. but yeah, USA built DSM's used alot of Borg Warner components. Technically you could convert to an aftermarket setup, but I would think getting the car to run right is a higher priority than risking more issues.
Are these the dual-tower coils? Its possible you can use GM dual pole coils if they also use similar transistorized ignitors.
Old Oct 29, 2004 | 02:45 PM
  #54
Sirius_GTO's Avatar
Guys, from now on order from Talahassee Mitsubishi. Number is 1888 825 5648.
25 percent off any part if you are a register member of a car club.
I just got my Coilpack with bracket for 116 shipped!!
Trung
Old Oct 29, 2004 | 05:31 PM
  #55
Jaylenospoolboy's Avatar
Just remember you may need a new ECU after you install the coils. I take it they're the OEM that you just ordered.
Old Oct 29, 2004 | 05:45 PM
  #56
Sirius_GTO's Avatar
Why do I need a new ECU after I install the coils.
yes they are OEM. I just bought the whole coilpack with bracket from mitsubishi.
trung
Old Oct 29, 2004 | 11:09 PM
  #57
Because the non OEM coils may have fried your ECU which is giving you the bad codes.
Just a hunch. I'm not an expert. But you might want to keep it in mind if the car continues to throw the codes.
Old Oct 30, 2004 | 07:20 AM
  #58
Sirius_GTO's Avatar
the coils on my car are OEM, and havent been changed yet. They codes came on when the OEM coils were on the car.
I ordered OEM coils and havent been installed yet.
My ECU is good to go. I've checked
Thanks,
Trung
Old Nov 7, 2004 | 08:57 PM
  #59
Sirius_GTO's Avatar
I found out it is a bad injector.
I will update.
Thanks,
Trung
