Dynoflash vs. SAFCII
Old Oct 26, 2004 | 06:31 PM
DSMotorsport's Avatar
I have stock injectors as well..
after full exhaust
afc, wideband
K&N filter
The next thing you reaslisticly should be looking at is upgrading the clutch.
after the clutch...Id say cams.
FMIC isn't worth doing with the stock turbo for the $ it costs.
after the cams, at high boost your going to run into a fuel cut issue.
there you have 2 choices...
1 reflash the ecu to remove the fuel cut and raise the ignition timing if running high octane
2 larger fuel injectors + tune the AFC leaner to compensate...that increases the ignition timing and lowers the airflow signal below the fuel cut.
either way works.
I haven't done any first hand testing past that point.
Old Oct 26, 2004 | 06:39 PM
EVO Neil's Avatar
after full exhaust
afc, wideband
K&N filter
either way works.
Your advice sounds logical, what AFC are you using or would you recommend?
Old Oct 26, 2004 | 06:46 PM
DynoFlash's Avatar
That is debatable at best.
the advantage a flash has over and AFC:
adjustment of ignition timing
raising of rev limits...not an advantage with stock turbo at all
removal of fuel cut...that is an issue unless you buy larger injectors.
the advantage an AFC has over the flash:
use adjustability
the ability to tune to conditions
ability to have seperate maps for different octane fuel
abiltiy to change settings to accomadate different injectors/fuel pressure change on the spot.
I highly doubt a flash will overpower a correctly tuned afc in any condition. That's just "Cheerleading" without any test data.
DSmotorsport - thanks for your insight into this subject
Now its time for me to add some of my ideas to this subject
First - the SAFC is a great little device and with the right hands it certainly can yeild some super results. However - it has some serious limitations for tuning evos. Let me discuss a few of its short commings.
The SAFC adjusts the a/f ratio by reducing or adding to the MAF sensor signal by a fixed percentage. In most cases the SAFC will require at least 13 - 15 % reduction in MAF signal to dial in a resaonable a/f ratio after 6,000 rpms on an evo due to the significantly RICH factory OEM tuning maps. This 13 - 15 % correction has the very UNDESIRED consequence of telling the ecu there is LESS LOAD on the car and thus moving the tuning reference into a much MORE ADVANCED IGNITION timing area on the ignition timing maps.
The problem is when you run the more advanced - partial load igniton timing maps on pump gas you gain significant detonation which results in the ecu "hearing" knock through the knock sesnor and pulling timing. This results in a very rough power band and low torgue.
Here is an example of this which was on my own car - back last MAY of 2003 when I had first gotten my evo - this was with an Exhaust, Buschur Intake and bost cntroller with a safc
Realizing that without some controll over the ignition timing my car would be running rough and unsmooth, I decided to try out the only available (at the time) solution - the Greddy Eamange which allowed me to adjust the ignition timing while also correction the MAF sensor signal much as a SAFC would. You will note that I made the same exact whp - BUT - I was able to gain significant trq down low and also smooth out the power band
Now - you may say that this comparision does not relate to a reflash - so lets look at a test done by Buschur Racing comparing the Buschur Flash to the SAFC which they also sell
http://www.buschurracing.com/EVO_Stage3.html
On that page you will see a discussion on how the Buschur Flash increases trq and smoothness
and stage 4 results are here - again more low end power
http://www.buschurracing.com/EVO_Stage4.html
Finally - the SAFC can not present a soluton to the issue of the multiple fuel and ign maps in the factory ecu
The stock ecu has a feature which moves the tune from lean to rich and also adjusts the timing between two main fuel and ign maps. The problem is when you tune with a SAFC alone you never know where you are - which map you are running and in time your tune may be thrown off significantly when the ecu moves from one map to the other
Some of the other benefits of my flash over a SFAC are :
1 - Idel fix for cams
2 - Fuel cut removed
3 - Higher rev limit
4 - No cuttng of factory wires
5 - No installation
6 - Lower cost
7 - Nothing to break
Now - onto some logistical issues - MOST Evo owners do not have the equipment of desire to experiment on thier own $30,000 cars which they rely upon for daily transportation. Tuning with widebands, OBDII scan tools and your own but dyno requires experience and practice and a wrong move can have bad results. The reflash is geared towards clients who want a simple, easy, plug and play solution. They dont have to worry about issues and problems.
This is from Apexi's web site
"Due to the complexity of this product, A'PEX recommends having the S-AFC and other A'PEX electronics installed and tuned by authorized A'PEX Power Excel Shops."
A final thought - for those who like to tinker - my $199 through the mail flash - combined with a SAFC gives you all the benefts of a reflash - comined with the end user adjustability which you mention. I have many customers running 11 second evos with that combination. It gives you the ability to start out with a gdo base flash with the ignition timing fixed and the tune close to very small SAFC adjustments will be sufficent. When you add race fuel or additional mods a savy user can quickly fine tune the car with very good results.
I hope this has addresed some of your questions
Old Oct 26, 2004 | 06:48 PM
DynoFlash's Avatar
Last I checked the ECU bases it's timing curve of the mass airflow meter.
The AFC simply adjusts the airflow signal from the mass air meter.
so the AFC adjusts fuel delivery and ignition timing at the same time inversly.
Im not looking for a fight by any means, and I dont know everything.
I do however know alot, as Iv been around the block modifying turbo mitsubishi's for 6+ years.
Im not going to argue with you, Im simply giving correct and accurate information. It may not be what you want to hear, but it's true and accurate.
Ths main disatvantage being that without INDEPENDANT control over each you are effecting one (timing) while you are adjusting the other
Also - the factory timing maps are very rough and uneven
Old Oct 26, 2004 | 06:51 PM
HREVO's Avatar
Thanks for the input, probably be calling in a few weeks to get the flash also. Are you going to be in the Denver, CO area any time for custom tunes, or everything has to come to your shop?
Old Oct 26, 2004 | 06:52 PM
DynoFlash's Avatar
doing both gives you the best of both worlds. you get the removal of fuel cut which is probobly the best feature of the flash. Raised rev limit. And added ignition timing.
The afc gives you used adjustability to fine tune your car to the currect conditions/modifications.
only downside is paying $ for "redundant" stuff.
I agree that a combination of both is a good idea
The main benefits of the flash to be used with an SAFC are
1- scaling of injector maps
2 - getting the a/f ratio much closer than stock maps - thus needing less % SAFC corrections
3 - Optimizing the ignition timing maps
4 - Making the gap between the two main fuel and timing maps closer so your tune will not change as dramatiaclly based upon knock and collant temps
5 - Giving you a car that can run without the SAFC (in case it goes bad)
6 - Giving you the ability to fine tune with your SAFC at the will of the end user to accomidate race fuel and or additional mods
DynoFlash's Avatar
I am actually thinking to try and come there for a tuning meet - BUT I am thinking it may be getting close to winter conditions there ???
Old Oct 26, 2004 | 06:54 PM
DynoFlash's Avatar
I prefer the emanage with the pressure sensor option
The SAFC is a 2nd choice
I find the HKS unit too hard to use
Old Oct 26, 2004 | 06:57 PM
DynoFlash's Avatar
is that even if it is a mail-in flash?
I offer a full range of customized through the mail flashes to match all the comon and typical modifications - intakes - exhuasts - cams - etc etc
You send in a list of mods and fuel used and we select a good base map for your application
Of couse the custom tune is much better in all cases - however for those geographically distant or planning more mods in the near future the $199 through the mail flash is a big bang for the buck
Old Oct 26, 2004 | 07:11 PM
TURBODAWG's Avatar
Dynoflash mail in and SAFC is the way to go IMO. I ran 118.7 mph with this combination. I use it exactly as Al explained. It is tuned well with 93 octane, but when I run race gas I lean it out more with the AFR and it has produced good results. The power curve and torque curve are much improved with the dynoflash mail in.
Brian
Old Oct 26, 2004 | 07:16 PM
GREDDY's Avatar
I have buschur stage 1 plus Injen intake and upper intercooler kit(pretty much like Buschurs stage 2 if you want to call it that). Just running SAFCII and dyno numbers are very similar to others with Buschur stage 2 and Als dynoflash. Torque is right up there with horsepower. I'm pretty satisfied with SAFCII.
Old Oct 26, 2004 | 07:17 PM
EVO Neil's Avatar
Good input Al.
Old Oct 26, 2004 | 07:32 PM
DynoFlash's Avatar
Could you kindly post up a dyno sheet? I would be interested to see what it looks like with 91 octane.
Old Oct 26, 2004 | 07:39 PM
DynoFlash's Avatar
One more flash advantage - with the Buschur Flash Stage II - dual stage flash is avialable - same flash has BOTH your race gas settings and pump gas tune
Here is the pump gas sheet - 20.5 psi bost - 93 octane
Here is the same exact car - race gas and higher boost
A nice option
Old Oct 26, 2004 | 07:40 PM
DynoFlash's Avatar
Here is my latest dual stage flash dyno sheet
Mods on car were
Buschur intake filter
3" exhaust
Hallman MBC
Walbro pump
Buschur injectors
Red lines are 21 psi of boost - 93 octane with Dyno Flash dual stage
Blue lines are 25 psi of boost - 100 octane mixed in - NO Changes made to tuning - same exact dual stage flash
This car was so fast it spun the inside front tire all the way through 2nd gear - twice - (this was a first) - PS I love those '04 evos
