Exhaust vs Dynoflash
Old Oct 27, 2004 | 03:33 PM
HREVO's Avatar
I just purchased an SAFCII, datalogger and apexi power intake and currently have MBC and gauge installed. Right now I am at a choice of either getting a flash or 3" turbo-back exhaust. how effective is the stock 2.5" exhaust setup? Just wondering what opinions are of which to get first.
Old Oct 27, 2004 | 03:38 PM
Dr. Fob's Avatar
Probably exhaust. The stock design is only 2.5 inch in diameter, and has quite a few bends near the rear axle. The Cat is restrictive too, so freeing all that up would allow your engine to run much more efficiently. The difference is night-and-day, and leaning out the top end with your AFC will give you that extra kick as well.
Old Oct 27, 2004 | 05:05 PM
Aby@MIL.SPEC's Avatar
go with the 3" turbo back exhaust. Best gain on my car. Here is my ratings for my mods with respect to gain in seat of the pants hp. 1=tubo back, 2=flash, 3=hks cams.
You'll get 60% of the way there tuning your safc.
4-BNGR's Avatar
If you never will go with a turbo upgrade the 2.5" will make more power (torque) all mods being equal
I recommend Buschur's 2.5"DP and 2.5" muffler delete pipe.
Old Oct 27, 2004 | 05:10 PM
merc300's Avatar
id get exhuast then a turbo trix flash
Old Oct 27, 2004 | 05:32 PM
lil'evil_evo's Avatar
I would go turbo back 3" not 2.5" and then custom dynoflash.
Old Oct 27, 2004 | 05:39 PM
steveevo8's Avatar
is the stock exhaust not 2.25"????
Old Oct 27, 2004 | 07:11 PM
HREVO's Avatar
cool, 3" it si then flash. I haven't found any links for TT flash only dyno. Anyone have a link or more information on TurboTrix?
Old Oct 27, 2004 | 07:20 PM
MYEVOVIII's Avatar
Exhaust and then Dynoflash. That way you dont have to have another tune once you get the exhaust.
Old Oct 27, 2004 | 07:34 PM
JTB's Avatar
JTB
Both if you can. You need the tune to really take advantage of the exhaust. If you can, also do cam gears before the tune -- with all 3 you will see a lovely bump in power!
Old Oct 27, 2004 | 07:36 PM
umiami80's Avatar
3 inch turbo back is the only way, then get a flash.
Old Oct 28, 2004 | 11:39 AM
HREVO's Avatar
torn between cam gears or 264 HKS cams, then flash....still doing the 3" asap. What do you think about gears or cams-and are they a DIY install (cams and shafts)?
Old Oct 28, 2004 | 01:02 PM
JTB's Avatar
JTB
This might be of help:
Evomoto Cam Install
