View Poll Results: Have you removed the clutch restrictor?
Yes
33
36.26%
No
58
63.74%
Voters: 91. You may not vote on this poll
Clutch Restrictor Removal
Old Nov 15, 2004 | 02:51 PM
  #46
evo81's Avatar
Originally Posted by redevo561
Hey guys i had my restrictor off since my stock clutch was on and it was great recently just got a act clutch put and and wow huge diffrence engagment is awsone and response is ever better i think wiihout the restrictor is better in my standings
put it back in.i just blew my tc.i had the act installed about 3 weeks ago.it feels better but not worth the tc damage
Old Nov 15, 2004 | 03:54 PM
  #47
marksae's Avatar
Clutch drops will break your t-case whether your restrictor or not. Change your driving style and your t-case should be fine. Learn to slip the clutch when launching.
Old Nov 15, 2004 | 07:20 PM
  #48
Zeus's Avatar
...yes, slip a little, but not burn it. Of course this is easier to do once you remove the restrictor, but again, I would say that removing it may not be for everyone. To date myself... "some people can screw up a free lunch".
Old Nov 15, 2004 | 07:30 PM
  #49
evo81's Avatar
i didn't launch the car.i always slip the clutch.this happen to me after i was pulling in 5th gear going at least a buck20
Old Nov 15, 2004 | 10:49 PM
  #50
marksae's Avatar
How did your t-case fail? If your t-case failed w/o you doing any crazy launches on it, it would have failed regardless of whether or not your restrictor was in there.
Old Nov 15, 2004 | 11:08 PM
  #51
marksae's Avatar
evo81, what oil did you use in your t-case after you installed your new clutch?
Old Nov 15, 2004 | 11:17 PM
  #52
evo81's Avatar
i never checked after i had it installed.i used the oem lsd oil before.oh shat! i brought some bg fluid for the install.i wonder if he put that in there
Old Nov 15, 2004 | 11:33 PM
  #53
marksae's Avatar
If your t-case was fine before the clutch install, then the cause of your failure most likely has to do w/ something that happened during the install. If you didn't do any launches on your t-case since the clutch install, then this failure sounds totally unrelated to the clutch restrictor.
Old Nov 15, 2004 | 11:36 PM
  #54
evo81's Avatar
just pm'd ya with a dum question.i been trying to contact the person who installed the clutch.i thought it was weird that it went like it did.have to be the install.
heliarcpro
Feb 26, 2017 01:59 PM
bvliz
Nov 14, 2016 01:18 PM
just a neon
Evo X How Tos / Installations
Aug 21, 2008 08:15 PM
evoviiiyou
Nov 14, 2005 06:13 PM
