Dialing in cams correctly?
Old Nov 7, 2004 | 04:03 AM
T()()L's Avatar
Hi.
Have a few question for you guys that are using a 360 degree wheel and indicator watch for dialing in your cams correctly.
I seem to have lost 14 degrees in duration,since i only get 250 in total duration (cams are Jun 264)
Starts to open 28 deg BTDC
Closes totally at 42 deg ABDC
28+180+42=250 in total : (
Headgasket is abit thicker but in has been encounterred for.
Messurement points has been dialing in TDC for piston,then zerod the dial plate at this pos,then messurements done on the titanium retainer.
Is it the lash adjuster and rocker arm than are spooking me up here or is i doing any thing wrong.
Suggestions wanted plz.
Old Nov 7, 2004 | 05:39 AM
JustDSM's Avatar
You need to locate yourself two solid lifters to properly degree your camshafts. Your Hyd. lifters are throwing your numbers off. I would not however expect your measured values to match JUN's advertised duration of 264.
Chris@nolimitmotors
Evo 'For Sale' Engine Internals and Drivetrain
400
Jan 26, 2017 08:25 AM
Boostin Perform
Feb 8, 2014 08:44 AM
rocketmotor
Aug 4, 2013 12:35 PM
erioshi
Mar 29, 2010 03:39 PM
