Need some info
Old Nov 8, 2004 | 05:12 PM
dryad001's Avatar
Need some info
I have been milling about the whole turbo upgrade thing for some time now, and i think I am finally ready to make a purchase, but still need some different ideas from you great people.
I was looking into getting the ATP 3071 turbo kit, just because it makes the power I want and I probably won't upgrade after all of this. But here's what's been stopping me everytime. Do I buy everything all at once, for instance the turbo kit, cams, IC, clutch, UTEC. Which I'm sure I could do everything except the clutch in a weekend. Or should I do all the small things first before the turbo kit just so it's less to worry about? I have been thinking to get the UTEC first to get to know the system then I can just upgrade away. C'mon people help me out. Please.
Old Nov 8, 2004 | 05:25 PM
Kwman's Avatar
I (once i again i would say I) would buy everything at once but after installing a few parts check and see if your car is running right, test them not necesarily individually but pretty thouroughly to make sure everything is peachy when running together. It's like writing a program make sure each class of objects works well before moving on to the next. A new turbo is a pretty big install so do it in stages. And yes getting the Utec and learning it first would be a good idea IMO. Just make sure you can tune well for the modifications you are about to install. just my .02
