upgrading to evo 6 turbo...need info
Old Nov 9, 2004 | 09:19 PM
SRT-4-st-3's Avatar
i own an srt-4. ihave stage 2, and im upgrading to stage 3 in feb. i want to know some facts about the evo 6 turbo TD05HR-15GK2-10cm2. what mods work well with it? does anyone know what the max psi/hp ratings of this turbo is? any advice would be helpful.
thanxx in advance.
Old Nov 10, 2004 | 04:42 AM
SRT-4-st-3's Avatar
bump...?
Old Nov 10, 2004 | 05:07 AM
Az3ar's Avatar
stright from the site
This is the EVO6.5 RS T.M.E Titanium shaft turbocharger with larger 10.5cm^2 Turbine housing. Fits all EVO4-EVO8 cars and offers a larger, less restrictive turbine housing made in A3N material that is less affected than the standard F5 material by anti-lag systems and elevated EGT’s.
The Titanium Aluminide turbine wheel and shaft is 33% lighter than the standard Inconel 713C turbine wheel and shaft. This enormous reduction in the rotating assembly inertia is Mitsubishi’s response to the demand for ever increasing shaft acceleration rates and decreasing turbocharger spool-up. The Titanium Aluminide material is also significantly more stable at 1600F than Inconel 713C.
The effect of increased lag of this larger exhaust housing is more than offset by the increase in spoolup provided by the lighter rotating assembly, resulting in faster than stock EVO8 turbocharger spoolup with increased top end power. Our AEM EMS datalogs show a .3 second boost recovery to 25psi during shifts while producing in excess of 370whp through the stock intercooler!
Old Nov 11, 2004 | 08:20 AM
SRT-4-st-3's Avatar
thanxx i couldn't find anything worthy about the turbo. i was hoping the the turbo could support 400hp. it looks like it will be close.
Old Nov 11, 2004 | 08:30 AM
Az3ar's Avatar
It’s a great track turbo. Simply the best you can get for the track beside the GT2871R. But the TI 16G is completely bolt on keeping the stock oil return lines and so on. For QM track it won’t give you anything lower than high high 11s with a great driver. In the end ask yourself do you want a monster track car or a drag car or both....
Old Nov 11, 2004 | 08:34 AM
MalibuJack's Avatar
Hmm.. Its the HR turbo not HRA, so it isn't the titanium turbine or shaft.. However its a great all-around turbo.. produces good power and has stable boost.
Out of curiosity, the SRT-4 is also a reverse rotation turbo correct? Someone has released an exhaust manifold that bolts up to the twin scroll turbo on the Neon?
Old Nov 11, 2004 | 11:53 AM
SRT-4-st-3's Avatar
i dont know if they have released an exhuast manifold, but i do know that the manifold is unique it bolted to the turbo. this is the same with the upgraded tdo5 turbo. there are also issues with aftermarket downpipes due to this weird turbo design.
thanxx Az3ar i would love to reach high 11's, but with the traction issue i'll be facing it will be more like low 12's.
Old Feb 20, 2005 | 07:06 PM
SRT-4-st-3's Avatar
update... my turbo should be here in about a weak....i've found out that it is titanium aluminide shaft. i should be able to get 400 hp out of her. just curious what is the best turbo that mitzu makes?
Old Feb 21, 2005 | 06:38 PM
SRT-4-st-3's Avatar
anyone know the max psi this turbo can achieve?
Old Mar 4, 2005 | 04:16 PM
SRT-4-st-3's Avatar
finally finished the install thurs night, and stage 3r is crazy....mitzu may not make the biggest turbo's in the world but they make a precise one. they really paid attention to detail with this turbo. the ti-al wheel makes all the difference. spool time is tire peeling fast. much thanks to mitsubishi for this beautiful turbo.
and thanxx for you guys info!
Old May 10, 2005 | 05:15 AM
Pingu's Avatar
What does the A mean in HRA or ?!
Old May 10, 2005 | 05:28 AM
GTVEVO's Avatar
Yes it is a reverse scroll turbo. The stage 3 turbo comes casted inside the manifold. A very odd design. In other words if you wanted to every change the manifold you would have to change the exhaust and o2 housing of the turbo. I couldn't believe it myself so I had to look at it for a while. But still it is a slick and very well built desgn. I have included a page that has pics in it.
http://www.modernperformance.com/dcx...tage3kit.shtml
Regardless the turbo is a very good fit and performs very well in a stage 3 car. A local friend has this setup and it is impressive. I would say on his car it is probably 400whp. Probably is , it won't stay on the dyno to test it. Everytime the turbo spools up the front wheels torque and it wants to walk off of it. DynoJet dyno that I really dislike for a frontwheel drive car. Next month I am trying to get him to a Dyno Dynamics to get it tested, if he does I will let everyone know what it ran.
Old May 10, 2005 | 06:57 AM
Noize's Avatar
EvoM Administrator
It sounds like the TME GSR turbo, since its a 15G and not a 16G. Anyone else catch that?
