Hi-flow cat?
Old Nov 10, 2004 | 04:17 AM
Demon187's Avatar
Hi-flow cat?
Could someone please tell me what the difference is between a stock cat, hi-flow cat, and a test pipe is on a turbo back exhaust. How much restriction is there, and is there a noticeable hp gain. Thanks in advance
Old Nov 10, 2004 | 05:05 AM
Cirrusly Evolvd's Avatar
A hi-flow cat is just that, a higher flowing catalytic converter. It's built much the same way as a stocker but with less-dense material and chambers.
A test-pipe is just a section of exhaust nothing inside.
You will get the most hp gains from the test pipe since it has no restrictions to the exhaust flow. The high flow cat will offer a gain over stock but not near as much as the test pipe.
Old Nov 10, 2004 | 02:50 PM
JaguarS4R's Avatar
Are either of the test-pipe or high-flow cat legal? Which is more noticable as far as rotten egg smell and more smoke? Or is it the same? Whats the HP difference between Stock, Hi-FLO and test pipe.
Old Nov 10, 2004 | 03:01 PM
twinevo's Avatar
high flow cats are legal. running without any cat is highly illegal.
Old Nov 10, 2004 | 05:48 PM
EvoTech's Avatar
From High Flow cat to Test pipe with no other changes yielded 15 more HP! Dyno verified
Old Nov 10, 2004 | 07:45 PM
johny719's Avatar
are you sure about that? I doubt the test pipe will yield 15 more hp over the High flow... do you have any dyno pictures? anyways... I heard that Hi-flow's after a while might shrink the margin of passing smog...
Old Nov 10, 2004 | 09:17 PM
Demon187's Avatar
Thanks for the reply everyone I think I'll be going with the hi-flow cat. I don't want to swap anything out for emission testing or have to deal with fed. fines.
Old Nov 10, 2004 | 09:27 PM
bluebanana23's Avatar
My hi-flow cat is half the size of the stock one and I personally do not think it will pass emissions but I atleast it will keep me from fines, louder exhaust note...
Old Nov 10, 2004 | 09:49 PM
marksae's Avatar
I'll be getting a high-flow cat soon for the extra performance and also to save my stock cat from the abuse. I plan on keeping my stock cat for smog tests. High flow cats seem to fail after about 3-5 years of use.
Old Nov 10, 2004 | 11:47 PM
mybada's Avatar
If you live in CA, don't even think about test pipe! Just like twinevo said it is HIGHLY ILLEGAL in CA.... but then everything is illegal in people's republic of california so i guess it's all up to you
Old Nov 11, 2004 | 01:05 AM
simevo's Avatar
I have the Helix HF Cat. I like the added HP but don't like the extra exhaust noise and exhaust smell. A test pipe will be even worse.
Test pipe will give the most HP but you'll need a CEL fix and the exhaust will be pretty loud and it will stink much more. Also, I've heard with test pipe, you'll shoot flames out the tail pipe.
Old Eagle
25
Feb 25, 2011 02:58 PM
johny719
26
May 18, 2005 07:38 PM
SinCityEvo
Oct 8, 2004 09:28 AM
BLiu
10
Apr 26, 2004 01:52 PM
Justin1933
19
Oct 30, 2003 01:54 PM
