1st Gear Synchro Wear? Or ???
Old Nov 16, 2004 | 09:27 AM
plokivos's Avatar
well, they're telling me the aftermarket clutch amplifies whatever issues that we had before with our stock clutch.
Like it's hard to put the shifter in the gear in the morning with stock clutch, and now it's harder to put it in gear in the moring when the car is cold. Reverse too, I really have to work at it. But after the car is warmed up, it's smoother.
Something about the fluids not warming up that's causing the shifter to go in harder in the morning when the car is cold...
The dealer I went to is fantastic. They actually installed my clutch so they already knew about the situation. They already put in Exedy, ACT and few Carbon Carbon disc on evo's already. They already took the transmission off of evo 7 several times before the evo 8 launched in usa so it's good.
Old Nov 16, 2004 | 09:30 AM
plokivos's Avatar
Originally Posted by tweist99
I also replaced my x-fer case fluids which seemed to smooth things up a bit with my shifting.. dam i just read your sig..... 220lbs it must be a workout to tweak your car, i mean i am only 140 and its still fusterateing sometimes for me... no wonder your car is still stock jk.... anyways i replaced my fluids with royal purple. I am impressed that you would talk to your dealership about having a aftermarket clutch in there... they must realy like you or something.. well that or u dont care about your warrenty.
L-8
Skinny @#$ white boy.
lol. Yeh, biggest problem is my shoulders not fitting between the seats and the floor. It's a headache, especially the recaro seats. I have problems with breaking things off of my car.
Old Nov 16, 2004 | 02:18 PM
Ookami's Avatar
We tried adjusting the master cyclinder rod but it did nothing. We then had to adjust the ... shift linkage! Pulling the smaller shift linkage (small bushing) towards the driver's side of the car and having another person try to move into first gear made it smooth as butter to get into. The problem however was where to adjust this. The location to adjust is a bracket, while looking at the shift linkage. It's towards the front of the car which is attached to the transmission. It's gold(?) in color... we adjusted that and it was good to go!
Thanks for all the suggestions, I hope this solution helps someone in the future.
Old Nov 18, 2004 | 03:48 PM
redevo561's Avatar
Hey ActMan i have a question i just had my act clutch installed about a week ago when i first got it was nice and engadged nice now i have about 500 miles on it and its finally broken in but now the clutch is engadgeing real high and doesnt feel like any pressure is going to the clutch check the stainless steel line but it was not leaking can it be the salve ??? its brand new clutch highley doubt its fried i havnt ran it hard either thanks
Old Nov 18, 2004 | 08:46 PM
plokivos's Avatar
adjust your master cylinder rod.
Old Nov 19, 2004 | 07:02 AM
redevo561's Avatar
is that the rod under the car that you had pictures on turning it conter clockwise correct ?? and how many times should i do it ? thanks plok
Old Nov 19, 2004 | 07:20 AM
WildRice's Avatar
Wow.. my ACT works perfectly. Once the line and slave are properly bled you shouldn't need to adjust the rod as that is only to contol free play in the pedal at the top. You do not want to pre load. If your stock clutch was adjusted properly then you should not need any changes with a proper install on the ACT.
Old Nov 19, 2004 | 07:48 AM
redevo561's Avatar
well my stock clutch was slipping really bad but i wouldent think that would of missed up my engagement correct?? thanks
Old Nov 19, 2004 | 09:38 AM
redevo561's Avatar
i now have a act clutch installed
Old Nov 19, 2004 | 12:17 PM
plokivos's Avatar
no your clutch would of. But new clutch need adjustment. along with that shfter link adjustment.
Old Nov 20, 2004 | 12:06 AM
redevo561's Avatar
how do you adjust the linkage ? thanks im going to adjust the m/c rod first thing tomarrow for some reason feels like its not engageing all the way but ill see how i it tomarrow
Old Nov 21, 2004 | 09:46 PM
redevo561's Avatar
Old Nov 21, 2004 | 11:11 PM
plokivos's Avatar
underneath your dash, following the clutch padle up, you'll see a little white push switch with blue plastic around it. Right above that to the left, there is this rod(screw) that's connected to the clutch pedal with a upside down U brace.
You'll need 12mm wrench and 6mm wrench. You have to loosen up the bolt stopper closed to the U bracket. Turn left to loosen, turn the rod itself to the right for faster engagement, left for slower engagement.
Don't do it too much, you should turn the thing only about 1/4 in and out and adjust from there.
Pictures are on the first page. Good luck, it's not that hard, it's just hard to get there.
Old Nov 22, 2004 | 06:07 AM
redevo561's Avatar
thanks
Synchrotech
484
Jun 11, 2025 05:14 PM
KillaYayo
Aug 31, 2016 07:31 PM
rcheung
Jun 27, 2009 06:35 AM
DanJ
Mar 19, 2006 05:48 PM
intolerance
38
Dec 29, 2004 04:33 PM
