Those with MBC ???
Old Nov 18, 2004 | 03:32 PM
GOKOU's Avatar
Those with MBC ???
I bought the car with the MBC on it already so I dont know how the stock one looks like. I hope it is the one that I've shown below. Did you guys remove the boost solenoid sensor or not when you put in the MBC? If not how did you leave it on there. Without the sensor the CEL comes on.
Thanks.
Old Nov 18, 2004 | 03:33 PM
JDM-Spec.com's Avatar
Show a better picture I could help you..... Talal
Old Nov 18, 2004 | 03:34 PM
The scilonoid is mounted under the stock airbox it is gold and black with two balck hoses one of which is striped white.
Old Nov 18, 2004 | 03:35 PM
mitsuorder's Avatar
Just leave the stock boost solenoid hooked up and in stock position unless it is in the way of something. If that is the case then just find another spot to fix it to as long as the wire can stay connected.
Old Nov 18, 2004 | 04:00 PM
GOKOU's Avatar
not sure what u mean but the picture shown was part of the stock MAS pipe
Old Nov 18, 2004 | 04:37 PM
Bom's Evo's Avatar
i just zipped tied mines away. on a bracket.
Old Nov 18, 2004 | 08:01 PM
GOKOU's Avatar
Can you help me out and take a picture of it on your car?
Thanks
Old Nov 19, 2004 | 07:52 AM
MitsuJoe's Avatar
Thanks.
I don't even know what you have pictures of. What you posted looks to be some type of device in the BOV return hole...a stock EVO does not come with that. However it does have a BCS and that is mounted to the frame rail under the area of your intake. It has two hoses coming from it and a electric plug goes to it.
When a MBC is installed the BCS is capped off and not used. Or at least this is how I would do it.
Old Nov 19, 2004 | 08:29 AM
bolsen's Avatar
No that's not the sensor. THe sensor is actually over by the chasis. Don't have a pict, but it's a small box with a plug that has two nipples coming off the end of it. IIRC, it's got some brass coloring on it.
Leave that sensor plugged in so you don't throw a cel.
Old Nov 19, 2004 | 08:42 AM
GOKOU's Avatar
The problem with me is that when I bought the car it already had a MBC and the plug for the boost sensor was left floating zip tie under the BR intake. My cel sometimes come on and I didn't realize it was that until now. The seller gave me the stock pieces but I don't know what the sensor looks like. I took a look at the stock air box and nothing. My guess is that he probably threw it away.
Old Nov 19, 2004 | 08:57 AM
bolsen's Avatar
you can't see it from the top gotta get under it.
Old Nov 19, 2004 | 09:05 AM
my3000gt's Avatar
Your boost sensor should be right under your BR intake. It is a gold metal device with two nipples on the end for hoses to connect to. This must remain connected to the wiring or you will get your cel to come on.
Old Nov 19, 2004 | 04:37 PM
GOKOU's Avatar
So does this mean that the sensor should be on the car? I'll look at the engine again tomorrow. The plug is under the BR intake there unplug.
Old Nov 20, 2004 | 10:21 AM
mitsuorder's Avatar
the harness connecting the stock, brass color, boost solenoid to the cars ecu wiring under the hood needs to be plugged in.
MajesticOne
Nov 20, 2016 02:34 AM
Motoxrider7
Dec 24, 2008 04:48 PM
EVIL_EVO_VIII
Jan 17, 2006 08:42 AM
forum04pl
Northeast Region
59
Apr 29, 2005 07:04 PM
BigLEVO
Apr 9, 2005 07:42 AM
