1psi and 1mph gain from 1g DSM bov
Old Nov 22, 2004 | 02:37 PM
propellerhead's Avatar
Originally Posted by HREVO
any info on where to find the flanges-yeah 1g crushed are very reliable and cheap.
RRE has them, as does Buschur. IIRC RRE's parts are more of a DIY project whereas Buschur's are "bolt-on", I *think*.
Old Nov 22, 2004 | 03:02 PM
GOKOU's Avatar
Originally Posted by 99AllTurbo
I agree that it's worth upgrading. I pressure tested my engine this past week. At 20psi the stk BOV held fine, but as soon as the boost gauge read 21psi, the stk bov leaked. On 100oct I set it to 24-25psi, so during those track visits the turbo was definitely being over worked. Then my friend let me bolt his Greddy type S bov on the car, pressurized the sytem again and the gauge read 25psi and no leaks from anywhere.
I will be upgrading the bov asap.
I was curious as to how you pressure test and found the bov to be leaking. Did you cap off the upper pipe? Was the car at TDC? When I did mines without capping off the upper pipe I can hear leak on the throttle body.
Old Nov 22, 2004 | 06:43 PM
DSMotorsport's Avatar
Originally Posted by Noize
That's a small enough difference to be attributed to a run-to-run variance, IMO.
I have atleast 1mph gain on 3 consecutive runs that were back to back. All better than my previous best ever runs as well as the runs from the same day with the stock bov.
I do have the AEM EMS boost logs that show a 1psi+ increase. I still haven't had time to get the logs off my laptop and capture a nice screenshot to post up here.
A small bov leak isn't going to make a HUGE differance anyway. 1-1.5mph is like 10-15hp at most. The most power gain that could be expected falls in the grey area of what could be through of as run to run.
The deal sealer for my own mind was the consistent gain in mph. Im very much the pesimist anyway...look at my posts regarding the FMIC I installed a few weeks ago that didn't gain squat. Im not a parts pusher.
Old Nov 22, 2004 | 07:53 PM
Fas4dr's Avatar
You must have a leak around the throttle body then. The only place air should be rushing out of is from valve cover breather. I have pressure tested my car at least 50 times and never heard any leaks besides the one I mentioned above.
Old Nov 22, 2004 | 08:08 PM
We stock them new and used, as well as the flange adapter to make it "bolt on" for the evo. I put mine on in 4 minutes in the staging lanes.
Old Nov 22, 2004 | 08:31 PM
sleet's Avatar
^^ So the New 1G Factory BOV for $86 on your site is a direct bolt on for the stock bov? Does it sound any different at all? Drive exactly like stock? If so then put me down for one
Old Nov 22, 2004 | 08:54 PM
you also need the little "flange adapter" we stock, but I don't think it's on the site yet...Ill get pics and setup the online ordering in the morning...belive the flange is like $23
at about $110 for the bov/flange is kinda expensive and getting into MR bov area. BUT we stock used 1g bovs for like $35
Old Nov 22, 2004 | 08:59 PM
ap-evo83's Avatar
From: RAMAR village, pampanga PHILIPPINES, Temecula, CA
are those the only mods you have right now at your car- the one listed in your profile?
Old Nov 22, 2004 | 09:10 PM
I have on the car currently:
AEM EMS in speed density
VRS 3" Turboback exhaust
2.5" cold air intake pipe with K&N filter (made it here)
HBC ES manual boost controller
Walbro 255
ACT clutch street disk
1G DSM BOV and adapter
boost and wideband gauges/mount
Stock:
FMIC, ic pipes,TB, intake manifold----will test BR FMIC with the new turbo
cams, unopened engine--stock till it breaks
turbo, exhaust manifold--soon to be BR440
stock injectors, fpr,rail ---soon to be 750cc
Old Nov 22, 2004 | 09:38 PM
EricJ@AMS's Avatar
We carry the flanges in mild steel, stainless steel and alluminum! The mild steel flanges are $10 bux and I'd have to check on the price of the others. Heres a page with some flanges listed: http://www.automotosports.com/DIY_flanges.asp
Old Nov 23, 2004 | 06:10 AM
GOKOU's Avatar
Well do tell me how to test it because I think some other people experience the same thing as I did. I've never touch the throttle body and the bolts are not loose. It sounds like it's leaking from the gasket on the throttle body or somewhere close to there. It may have been the breather also. I got tire of it so I cap the upper pipe since my main concern was the lower pipe, intercooler and bov. THe problem with this is that there is no vacuum on the BOV tube. Did your car had to be in TDC?
Thnks
Old Nov 23, 2004 | 07:17 AM
My car had a boost leak on one of the vacuum lines going to the emmissions equipment under the intake. there are 2 vac lines on top of the TB ( think white and yellow stripped), one that when I took off and plugged the hole with my finger...most of the "leaking" sound was gone.
Old Nov 23, 2004 | 07:30 AM
GOKOU's Avatar
Are you referring to the two lines that goes to the throttle body and have a making like A or G on it? My understanding is that one of those line must be plug and the engine should be at TDC in order to do a good boost leak test.
Others seem to have done it without any changes/modifications.
Old Nov 23, 2004 | 07:56 AM
David Buschur's Avatar
DSMMotorsports carries a full line of our parts now so I am not highjacking this from them
We have the 1G BOV's, flanges and an actual adapter kit for the EVO here instock. Something nicer that works really well is the Forged BOV kit, we have those too and they cost the same as the 1g valve and adapter.
You can contact them since this is their thread as they can buy from us.
David Buschur
www.buschurracing.com
Old Nov 23, 2004 | 09:51 AM
ShapeGSX's Avatar
Sorry Noize, not when a car is very consistent.
I'd definitely notice a 1mph increase on my car with the turbo running *****-out (and it does on every run).
Nate knows his sh*t, and he is datalogging everything.
