Problem removing TC from trany
Old Nov 21, 2004 | 08:01 PM
jfboy's Avatar
as some you guyz know , I am working on a werecked evo I am pareting out.. well I am having a problem remove the TC from the tranny. I removed all the 17 mm bolts. the i pried it off the tranny with a big screwdriver. it slid out very easily up to a 1inch gap between the 2 parts and it does not wan to go any further... ?? any tips on removing it any I should do but dont know about ???
Old Nov 21, 2004 | 08:04 PM
Kuba23's Avatar
My friend has the same problem on his EVO he claims there is something bent on the tranny and it wont come off unless you have the metal shop do it i dont know wtf he is talkin about but his engine is hanging in the air with the trans and the TC for about 2 months now if anyone knows if there are any tricks please respond
Old Nov 21, 2004 | 08:06 PM
93civEJ1's Avatar
did you guys use a slide hammer to pull the output shaft out?
Old Nov 21, 2004 | 08:16 PM
jfboy's Avatar
wich output shaft ??? on the passenger side ???? going to the passnger side axle ??
Old Nov 21, 2004 | 08:19 PM
DSMotorsport's Avatar
you need to pull out both splined shafts that the axles came off of. there is a 8mm 1.25 metric threaded hole in the center of both shafts. you can either attach a slide hammer to each, or bolt a few feet of a chain to the shaft and loop the other end of the chain to a big sledge hammer and swing the hammer away from the car to yank the shafts out. then tehe xcase/trans will come apart.
Old Nov 21, 2004 | 08:27 PM
jfboy's Avatar
thanks will do so... I dont get it why donmt they make the axles the male part like the honda's ?
Old Nov 22, 2004 | 05:20 AM
SuperHatch's Avatar
Just a clarification, you don't have to pull both, only the drivers side that goes through the transmission.
- Steve
Old Nov 22, 2004 | 08:09 AM
patsevo8's Avatar
Have your removed the starter? It might be a thought.
Old Nov 22, 2004 | 08:10 AM
SuperHatch's Avatar
The starter is on the opposite side of the motor from the TC. It will in no way stop you from getting the TC off.
- Steve
Old Nov 22, 2004 | 08:16 AM
2k4EvoVIII's Avatar
You dont need to do all that. All you have to do it take out the axles, remove the 6 17mm bolts, pry inbetween the tranny and the TC and it will seperate until it hits the C clip on the spline (just like the axles have) you just have to put some muscle into it and it will pop off dont be scared. I have done it on my EVO 3 times and walked another guy over the internet a 4th time.
Chris
Old Nov 22, 2004 | 09:29 AM
jfboy's Avatar
Chris
you mean I dont have to pop the splined shafts off like dmsmotors said
Old Nov 22, 2004 | 09:42 AM
bishiboy's Avatar
If you pry it off, you can break the c-clips. Use a slide hammer to remove the driver's side output shaft. Then it will come right apart. I just pulled my tranny.
Old Nov 22, 2004 | 10:13 AM
2k4EvoVIII's Avatar
I just rebuild the whole engine from the ground up and i didnt have to take the output shaft out. I mean yes it will work if you do take out the output shaft but yes it will work if you do not also. And there is a very very slim chance of breaking the C clip they are made to compress and expand. And if it were to break you are looking at a $1 part. OUCH!! Now look at how much a slap hammer will cost or how much it will be to rent. Big difference! Anyway you can pick. I can tell you i have done it multiple times without taking out the output shaft. Your decision.
Chris
Old Nov 22, 2004 | 11:48 AM
SuperHatch's Avatar
Chris
While agree that this method will "work" I will never agree that it's the right way to do it. And I don't find slide hammers expensive at all, a very cheap tool actually.
And that $1 part that you might break? Did you ever think that it could break and pieces could fall into the transfer case after it broke? That could end up being a very expensive fix if you're not farmiliar with taking apart a TC and reassembling it properly.
Do yourself the favor, get the slide hammer, do it the way recommends doing it, and walk away.
- Steve
Old Nov 23, 2004 | 06:01 AM
jfboy's Avatar
- Steve
what kind of bot di you use ?? it looks like a bolt from the fenders would work...
