Is my T-case screwed???
Old Nov 23, 2004 | 05:34 PM
90GSX-03EVO's Avatar
Originally Posted by plokivos
well, if he broke the spider gears, then you need to replace the syncros and the bearings...
it could be something else then the spider gears... maybe it's the end gears
There's synchros inside an open differential?
What are you talking about?
Old Nov 23, 2004 | 05:35 PM
Originally Posted by bs
But why would the noise go away??? I have been fearing that it's the front diff. The whining noise is a new thing that wasn't present before I launched the car. Should I have the fluids checked for metal?
Noise goes away in a straight line because the differential is not turning inside itself anymore, hence, it isn't sensing a difference in travel between the wheels (as it does while turning).
Old Nov 23, 2004 | 05:44 PM
11secEVO7's Avatar
hey if u need a transfer case let me know....
only problem is that I'm from the caribbean......but if u pay shipping, no scene
Old Nov 23, 2004 | 08:04 PM
bs's Avatar
bs
The noise while turning has also pretty much completely gone away. Seems weird to me....I can't explain it.
Old Nov 23, 2004 | 08:06 PM
bs's Avatar
bs
Oh and I was using stock T-case fluid.
Old Nov 23, 2004 | 08:27 PM
plokivos's Avatar
well if the spider gears in the differential breaks, it's going to effect the syncros and the bearings, that's all I was saying.
Old Nov 23, 2004 | 09:02 PM
It's going to affect the synchros in the TRANSMISSION?
How?
Old Nov 23, 2004 | 09:03 PM
You've probably ground all the teeth off of the spider gears and now there is nothing left to "grind" anymore.
Old Nov 23, 2004 | 10:08 PM
bs's Avatar
bs
So should there be any obvious symptoms of this on the street?
Old Nov 23, 2004 | 10:11 PM
bs's Avatar
bs
Ok so it's sounding more and more like I am going to need a new transfer case. Whats the best option for replacement....oem from the dealer?
Old Nov 23, 2004 | 10:18 PM
SilverEvo8owner's Avatar
My car is doing the exact same thing
It is louder on slow left turns
I dont think it the t case. For me it sounds more like the rear diff.
I have never launched the car in its life 40k on stock clutcj
Old Nov 23, 2004 | 10:24 PM
bs's Avatar
bs
hmmm thats interesting. my ears have been known to decieve me when trying to pinpoint where a noise is coming from in a car. to me it sounds like its coming from the front but perhaps i'm wrong. i'm taking the car tomorrow to check for metal in the fluids so maybe that will provide some answers.
Old Nov 23, 2004 | 10:41 PM
plokivos's Avatar
How?
If your spider gears look like this, you do.
Old Nov 24, 2004 | 11:00 AM
STOP WITH THE MISINFORMATION, PLEASE!
The front differential is in the transfer case. The transfer case is NOT inside the transmission. It sits behind the transmission and is sealed off, for all intensive purposes. Why do you think the transfer case and the transmission take different types of gear oils? If fluid from the transfer case can't make it to your transmission and touch your synchros, I seriously doubt pieces of your front differential could either.
If that pic you posted destroyed synchros, then it must have been a center differential, not a front differential. In fact, that looks like a stock 2 side gear center diff out of a DSM.
Center diffs were known to grenade like that on the DSM's. I've actually done it before.
Old Nov 24, 2004 | 01:19 PM
evo 8 ya's Avatar
I have a front diff out of a t-case that was on it's way out. If you want to buy it. Make a reasonable offer.
