HKS ssq with EIDS?
Old Nov 28, 2004 | 02:14 PM
Evoisdream's Avatar
wow not to be a jerk but u guys should really make a new thread with these questions im not even getting my answers now becuase they are talking about your stuff......
l
l
l
Originally Posted by Evoisdream
thanks jack for the info it helps a lot im not really worried about VTA im more then fine with recircing it but i just want to make sure b4 i order the recirc flange if that will even help? i have read a few things of people recircing it and still having some issues..... and in the case of me recircing it thier would be no point in haveing the eids correct? lemme know thanks
evoisdream
Old Nov 28, 2004 | 09:48 PM
EVOla_VIRUS's Avatar
^ lol I guess that would be frustrating.....but I think most or all would agree that a recirc system (closed system) would not need a stabilzation algorithm (aka EIDS) due to recycling accounted air. I dont see a problem with using EIDS w/a recirc BOV....when I placed my stock BOV back on for a while (dont ask....i do strange stuff like that sometimes lol) I had no problems at all w/EIDS .....just my opinion
Old Nov 28, 2004 | 09:54 PM
MalibuJack's Avatar
Yeah its best that you recirculate, essentially thats what all of the posts kinda eluded to.. If you do and don't have other leaks or issues, you shouldn't get any stalling.. However the EIDS won't harm anything by using it, its just that if its set to smooth the signal significantly you may find sudden throttle changes may feel "odd" or sluggish..
Your absolute best bet is to recirculate the SSQV if you really want to use it.. I have one that Vents to atmosphere, however i also have a blowthrough MAF sensor which means its no longer affected by dumping excess air to the atmosphere..
HOWEVER I don't particularly like the SSQV, But its the only unit that has not leaked under boost in my configuration.
Old Nov 28, 2004 | 10:11 PM
^ just curious...why dont you like the ssqv
Old Nov 28, 2004 | 10:15 PM
MalibuJack's Avatar
It flutters alot at part throttle, and gets a bit of compressor surge.. if you don't spend alot of time adjusting it.. unfortunately if you don't adjust it right you can damage the diaphragm in it, but if you adjust it too soft engine vacuum can draw it open and the car will just stall and run like crap..
Old Nov 28, 2004 | 11:05 PM
Evoisdream's Avatar
Yarg wondering about this set up now most likly will get the recirc valve since its 10$ and if that doesnt work ill have it all for sale and will probly just go with the MR dev valve.... thanks jack 2 bad i most likly wont b able to use it
Old Nov 28, 2004 | 11:08 PM
EVIL MR's Avatar
same here
Old Nov 29, 2004 | 05:00 AM
MalibuJack's Avatar
Yeah, unless you don't have a MAF sensor before the BOV (either a blowthrough or speed density setup) its just not worth the effort to get working right.. Oddly enough, the Blitz DD with the heavier spring works pretty well, but it does surge a little..
Old Nov 29, 2004 | 09:05 AM
DrBump471's Avatar
I use the Blitz DD, along with the Blitz SUS Power Filter, and the HKS EIDS and have little problems. I did nothing to reconfigure the spring but flutter/surge comes about when I am light on the throttle. WOT I have no issues.
The biggest problem is when it is cold out though. Living in Indiana it tends to get a little chilly. The RPMs jump all over the place while the EIDS is trying to work. To fix that, I put a switch in to turn on/off the throttle response from the EIDS.
In terms of setup you only get one of the dials to configure, rich or lean in the model for our Evo's. I have it a little on the more lean side.
If there are any more questions let me know. I will do what I can to help with their setup.
P.S. - In terms of hooking it up. The Yellow & White wires will break into the MAF sensor on the ECU. I forget which one is which. I will check if someone needs for me too. The Pink (I Think) is for the throttle. The rest is just power and ground.
Jason
Old Jun 20, 2006 | 07:29 PM
dadriva's Avatar
I had the HKS SSQ in the VTA configuration with the EIDS. My car was tuned by Al with this setup last week.
I have since removed the HKS BOV in favor of the Forge RS recirc unit. I am now recirculating 100% with this unit. I removed the EIDS and the car ran like crap, stuttering backfiring, and running very high EGT's at low speeds. I put the EIDS back on and the car runs fine again.
Is the EIDS hurting anything (throttle response, performance, drivability) to still be on the car when it is now recirculating?
Do I need to be re-tuned without the EIDS to run properly?
I realize these are prob. queations for Al but I am impatient and it is 10:30pm and I can't call him. Thanks!
Old Jun 21, 2006 | 08:06 AM
dadriva's Avatar
Morning crew bump....
Old Jun 26, 2006 | 08:02 AM
dadriva's Avatar
still no one with an answer?
Also waiting for Al to answer my PM.
Old Jun 26, 2006 | 08:06 AM
heSOshAdy's Avatar
Where is everyone purchasing their Recirc Kit? I am in dying need for one, please let me know. Thanks.
