Will i regret getting MBC?
Old Nov 30, 2004 | 11:34 AM
EVOTEXAS's Avatar
Originally Posted by Evoisdream
welp i orderd the Hallman Pro RX MBC with the in cockpit controll so im looking forward to it anyone have install directions or a link?
In the How To section. It's pretty easy. Just PM me if you get into it and have problems.
Old Nov 30, 2004 | 11:47 AM
bdking57's Avatar
I installed the hallman pro with incockpit controll not to long ago. You may want to check but i believe the best place to drill the control line is right underneath the either the brake line or the acclerator.. cannot remeber which one .. It was a pain in the *** but not that hard and pretty brainless install. For high boost applications like with the evo, most people are advising to put the T in between the intake manifold and the BOV.. so the little line next to the bov is fine, and the other tube goes to the waste gate actuator. you should mount it to the bolt on the radiator.. pretty easy.
Old Nov 30, 2004 | 11:55 AM
Evoisdream's Avatar
thanks guys this really helps i think it should b here by fri so if its not 2 bad outside sat ill install it and hit u guys up if i need help
Old Nov 30, 2004 | 12:19 PM
guitardave24's Avatar
Personally, I bought a Joe P MBC for my DSM and it took a while for me to realize it wasn't working quite well. It would never allow above 15 psi, but I didn't notice for a few months because it wasn't for a while that I needed to turn the boost up higher than that. Perhaps the spring or ball was locked in place or something. Then I bought a Dejon tool MBC and it worked great.
Joe is a great guy though, it might have just been bad luck on my part.
Old Nov 30, 2004 | 12:21 PM
Is it really necessary to drill? I haven't done it yet w/ my Evo, but in my DSM I simply poked a hole in the steering column boot and ran it through that. Not possible w/ Evo?
Old Nov 30, 2004 | 01:48 PM
Evoisdream's Avatar
i got the hallman one so im not 2 worried i have only herd good things so far ill let u guys know for sure when it comes in and how i like it install etc ill make sure to take pics
Old Nov 30, 2004 | 03:08 PM
mitsuorder's Avatar
I would suggest hooking the vac lines for the Hallman to the waste gate and turbo nipples, I had less than satisfactory performance when I had mine hooked up the other way.
Old Nov 30, 2004 | 03:25 PM
What do you mean? The "out" line from the MBC should go to the wastegate actuator the "in" line should come from the tee which goes between the intake manifold and the BOV. The intake manifold is arguably the best pressure source. Are you saying the "in" line for the MBC came from the turbo nipple? I know the BCS uses it, but I didn't think this would work as well for an MBC.
Old Nov 30, 2004 | 03:41 PM
mitsuorder's Avatar
https://www.evolutionm.net/features/...machvcorner/30
This has been the best method for me man, others have said to have success with the T off the diverter valve method but it was nothing but headaches for me.
Old Nov 30, 2004 | 10:26 PM
Jakeg97's Avatar
where did you purchase it from?
