OK, who can read this map???
Old Nov 30, 2004 | 07:30 AM
Az3ar's Avatar
I need someone expert to read this map and please try to explain to us as well. How much PSI this turbo can run and how laggy it will be on our 2.0 engine.
Old Nov 30, 2004 | 08:22 AM
EvilDylan's Avatar
im no expert, but it looks like you will have to run pretty high boost with this turbo, that or running low boost will result in real slow spool up.
Looks like its most efficient in the 29-35ish psi range.
and it looks like you might have some surging when you are building boost at low engine rpm's.
Im new to reading compressor maps, so i might be totally off.
Old Nov 30, 2004 | 08:27 AM
Az3ar's Avatar
No problems. at least you are trying to help
Old Nov 30, 2004 | 01:14 PM
PVD04's Avatar
Actually, I think the maximum efficiency range is from 17.5psi to 26.5psi (the center circle). I don't know a whole lot about compressor maps, but this all depends on the mass of air it is moving. As far as lag, I have no idea how to read that from a compressor map.
As far as how to read off the ideal pressure, the scale on the left is pressure ratio. The lowest level (1) is the same as 0 psi. The pressure is the same on both sides of the compressor (1:1). The center circle is where maximum efficiency is achieved, and it ranges from 2.2:1 to 2.8:1, which is about 17.5 to 26.5psi. The bottom is the mass of air flowing through the compressor. If you know the temperature of the incoming air and the volumetric flow rate, you can estimate the mass airflow.
Old Nov 30, 2004 | 04:59 PM
EvilDylan's Avatar
im pretty sure that the 1 is 14.7 psi
Understanding the Axis:
First we will start by looking at air flow through the turbo measured on the x-axis. Garrett uses lb/min on their maps while other companies like Mitsubishi use cubic feet per minute (cfm). Since I think it’s easier to work with cfm, we’ll convert. Every 10 lb/min is equal to 144.72 cfm, remember this.
The pressure ratio measured on the y-axis is merely the ratio of air pressure leaving to the turbo to air pressure entering the turbo. Since atmospheric pressure at sea level is 14.7 psi, if you were to run 29.4 psi of boost, the pressure ratio would be 2.
Old Nov 30, 2004 | 05:04 PM
Nad1370's Avatar
If you want to be excact....1 = 14.67
Old Nov 30, 2004 | 06:13 PM
Blitzbaster02's Avatar
The turbo will flow up to about 500hp, you can usually take about 2.5 pr and follow the line all the way over to the last circle, look down and see how much lbs/min you flow. In this case you get about 50lbs/min or 500 crank hp.
Old Nov 30, 2004 | 06:59 PM
Az3ar's Avatar
Great info guys. I am trying to gather more info... Surge and PSI as well.
Old Nov 30, 2004 | 07:30 PM
PVD04's Avatar
If you want to go by absolute pressure, then yes, the 1 is ~14.7psi, but if you want to go by what you are going to see on a boost gauge, it is 0. The pressure on the intake side of the compressor is the same as the pressure on the outlet of the compressor. If 1 were ~14.7 psi gauge pressure, then according to compressor map for the Evo 6.5 turbo, it is at maximum efficiency all the way to 30 psi. We all know that a 16G turbo is not at maximum efficiency all the way to 30 psi. There are a lot of things I do not know about reading compressor maps, but the pressure scale is one that I'm completely sure about.
Old Nov 30, 2004 | 07:48 PM
Crufty Dusty's Avatar
#1 Lag is correlated to the A/R. Smaller A/R = faster response but less flow at high RPMs.
#2 How much power you can make is determined by air massflow, fuel and ignition timing.
Old Dec 1, 2004 | 05:43 AM
EvilDylan's Avatar
thanks for being so EXACT.
Old Dec 1, 2004 | 11:21 AM
eve-slow's Avatar
here you go doods.
http://www.geocities.com/joesaccordpage/turbosizing.zip
http://www.majesticturbo.com/images/chart4.gif
http://www.honda-tech.com/zerothread?id=142398
Its all ya need!
Old Dec 1, 2004 | 03:42 PM
Ted B's Avatar
With the EVO's 2.0L motor, it appears this turbo would be in its most efficient range when delivering up to 26psi at 5000-5500rpm, and should be able to hold onto 24psi until maybe ~8000rpm. On race fuel, it should be able to give 28psi fairly efficiently until around 6000rpm, when it would begin to taper. It looks like it would ramp up on boost quickly between ~3700-4000rpm.
It's rated ~720cfm and is good for a theoretical ~500hp.
Old Dec 1, 2004 | 04:22 PM
Az3ar's Avatar
Thank you Ted. after all this Info this map is much easier to read now.
Old Dec 1, 2004 | 05:40 PM
AMS's Avatar
AMS
Don't get caught up reading too much into compressor maps. It's a good starting point but there is so much more to it. When you calculate PR you have to pre turbo delta P(air filter, pipe, ect.), and delta P from your turbo to where you would be measuring intake manifold pressure. To say that the turbo is putting out X mass air flow at 20psi does could mean that you only see 16psi on your boost gauge because of pressure loss along the way.
Also just because one wheel is bigger and the chart looks like should make more power it doesn't always go that way. I've tested a bunch of turbos' and sometimes the smaller, new, more efficient wheel will make more power.
here is an article I wrote about 3 years ago on how to read compressor maps, it's basic and simple.
http://www.vfaq.com/mods/Turbo-compressor-maps.html
-Martin
