RnR Turbo kit ..
RnR Turbo kit ..
This is info from the RnR site. I have a couple of questions, the site is a bit difficult to navigate. Who makes this turbo, Garrett? I think it is single b bearing, right? Is there a pic of the standard manifold? Has anyone tried this kit, it seems to be an excellent price. Any info would be great.
RNR L2R (60-1) 550WHP
We are now offering standard bearing turbos. We offer 3 levels, but can do a special set up if you desire.
Features:
T3/T40E Turbo
321 SS cast 8 gauge manifold
Jet Hot coated manifold
3" SS 02 Elim Downpipe(bolts up to 3" flange)
Tial 38mm Wastgate
SS Dump Tube
2.5" SS304 Lower IC Pipe w/silicon hoses and t-Bolt clamps
AN fittings
SS oil lines
coolant lines
SS bolts, nuts, washers, etc
SS gaskets
hose connectors
Everything needed to bolt-on to your car!
We have throughly tested these turbos on the 4G63 and have found great results with all these combos. So you can rest assured that you are buying a proven set up that is going to make a lot of reliable power.
Price: $2395.00
Features:
T3/T40E Turbo
Tial 38mm Wastgate
SS Dump Tube
AN fittings
SS oil lines
coolant lines
SS gaskets
hose connectors
Price: $2395.00
