HELP! MBC's ball and spring lost in engine bay!!!
Old Dec 7, 2004 | 08:22 PM
RSGuy's Avatar
Hello,
Earlier tonight I was trying to adjust my MBC. It was already on the lowest boost setting. However, I accedently turned the bolt the wrong way and the bolt, ball and spring flew out of the MBC, into the engine bay. I managed to retrieve the bolt but the ball and spring are still at large. What should I do? The car hasnt moved because I dont want to risk blowing my motor up. I'm thinking I have 2 options: either try to find the right parts at an autoparts store or take off the undertray under the engine and retrive the parts. Would an autoparts store have the correct type/size ball and spring? Any advice would be greatly appreciated. Now I need a smoke....
~fred
Old Dec 7, 2004 | 08:23 PM
GOKOU's Avatar
Try to find and get a magnetic pen
bluebanana23's Avatar
i dropped a lot of shat down there and i'm certain it's in the undertray. Have fun retrieving them.
Old Dec 7, 2004 | 08:25 PM
FlyTheFluffySky's Avatar
Take off the under-tray.... stupid thing catches everything.
Old Dec 7, 2004 | 08:39 PM
bpclements's Avatar
Sometimes things like to get lodged in your starter. I had it happen once when I was pulling my bov off. I dropped a 3 inch extension down there and it got lodge in my starter. I could never find it. Then the next day when I try to start my car nothing happened. Actually everything would just shut off because all of my voltage was being shorted directly to ground through the starter. I found the extention there and it was sortta charred up where it made contact with the starter and block. It didn't hurt anything though.
Old Dec 7, 2004 | 09:03 PM
RSGuy's Avatar
Will I be OK if I drive the car without the ball and spring inside the MBC? I definitely wont get into boost until I get this resolved.
Old Dec 7, 2004 | 09:12 PM
bpclements's Avatar
Yeah it will be ok to drive. Only problem is I don't know how well the car will idle since there is a vacuum leak where the ball use to be.
Old Dec 7, 2004 | 09:34 PM
superz's Avatar
Just drive the car but dont get on it, otherwise boost will be unlimited. DOnt bother trying to find another ball and spring, bite the bullet and get another MBC, its cheap insurance.
Gil-superz
Old Dec 8, 2004 | 02:00 AM
deekay247's Avatar
Get the hallman mbc. It has a safety knob built in for keeping it from turning out all the way. http://www.boostcontrollers.com
Old Dec 8, 2004 | 05:47 AM
sleet's Avatar
^^ Yeah, i've got the Buschur racing MBC now and i'll be upgrading to the Hallman very soon.
Old Dec 10, 2004 | 04:13 PM
Jakeg97's Avatar
start taking things apart and find the missing parts! or just buy an hallman mbc and dont worry anymore - www.boostcontrollers.com ships quick !
Old Dec 10, 2004 | 04:18 PM
tokeone's Avatar
i dont know if you have the controller set up from the throttle body/bov to the wastegate with the compressor housing plugged off or if you have the controller from the compressor housing to the wastegate, but if you run a vaccum line just from compressor housing to wastegate you should just run minimal boost (14psi)
just make sure that the throttle body line isnt still t'ed off and its only going to the bov.
