Buschur Racing dyno thread.....new developments.
Old Jan 26, 2005 | 10:21 AM
  #196
David Buschur's Avatar
Well that's good news on the price. Hopefully I am right. I need to check with Magnacore.
Thanks,
David Buschur
www.buschurracing.com
Old Jan 26, 2005 | 10:23 AM
  #197
Just called Magnacore. You were right. Retail for those two plug wires is, unbelievable, $102!
I will stick to our price of $55 each while we have them left. The next order I place I will probably have to raise the price.
Get them while they are cheap I guess.
David Buschur
Old Jan 26, 2005 | 10:25 AM
  #198
mitsuorder's Avatar
Holy crap! awesome
  #199
DynoFlash's Avatar
Originally Posted by davidbuschur
The plugs in the car have never been out.
The HKS Twin Power is what we are using on most of the EVO's we are doing. I will be testing it but I am going to wait until the car needs it. I don't think at this power level it will do much if anything.
David Buschur
BUT - I bet you would have thought the magna core wires would not have done much either ! When I tested the twin fire I was shocked by the results in the low end tq.
Old Jan 26, 2005 | 10:26 AM
  #200
Zeus's Avatar
My RS has only about 2500 miles on it. It also has about 230 dyno runs on it right now. I pulled the two plug wires off and replaced them with the Magnacore 8.5 mm wires we stock, but have only sold a set or two of. You would think on a new car it wouldn't make a difference. Wrong. The HP went up a few 3-4 whp in parts of the curve. The really amazing thing was how much smoother the curve was. The plug wires got rid of some small dips I had here and there in the curve. These wires, I have to say are a must have part even on a new EVO, atleast when the HP goes up from stock they are. I'm very impressed. These two wires are $55. I am going to have to do some hunting to double check that as it seems a little high for two plug wires, they did make a very nice difference though. I higher mileage EVO would be even larger.
David Buschur
David,
Sent you a PM.
Old Jan 26, 2005 | 10:28 AM
  #201
mike 99gsx's Avatar
I wouldn't be surprised if you dyno'd a few HP more by just swapping the stock plugs out for BPR7ES plugs.
  #202
Zeus's Avatar
Originally Posted by mitsuorder
Holy crap! awesome
Mitsu, I thought you had a set...
Old Jan 26, 2005 | 10:42 AM
  #203
Zeus's Avatar
Order placed online... I figure after 37k miles... it couldn't hurt.
Old Jan 26, 2005 | 10:48 AM
  #204
Zeus's Avatar
I'm thinking BPR8ES with 21lbs, 272's, stage 3 equivalent etc, etc.
Old Jan 26, 2005 | 10:53 AM
  #205
mike 99gsx's Avatar
You don't need that cold of a plug at that power level.
Old Jan 26, 2005 | 10:59 AM
  #206
Zeus's Avatar
I've seen arguement both ways...
Old Jan 26, 2005 | 11:01 AM
  #207
Jrod@Buschur's Avatar
We have 2 sets of wires left. They are going FAST.
Take Care,
Jarrod
Old Jan 26, 2005 | 11:05 AM
  #208
mitsuorder's Avatar
great of you guys to honor this deal
Old Jan 26, 2005 | 11:29 AM
  #209
Derek Baker's Avatar
Jarrod,
Thanks for adding the wires to my order.. Looking forward to see how everything works together..
Derek
Old Jan 26, 2005 | 11:32 AM
  #210
EVO8LTW's Avatar
FMIC dyno results
Pulled the car yesterday afternoon. The temps are over 20 degrees F hotter in the building today than last time. Ohio's weather sucks.
Using a non-corrected actual HP pull changing intercoolers in 20+ hotter weather did nothing although spool up was slightly better with the deluxe core, still would not make more peak hp. Now in the SAE corrected mode, which is what most of you want to see and have requested that, the Deluxe FMIC core made more HP from around 3500 up. Looks like around 6-8 whp. Personally and honestly, I don't believe it.
So that's 6-8 whp more for the Deluxe FMIC than for the standard FMIC kit that uses factory piping? Why don't you believe it?
