why does my car run better at 16 psi??
Old Dec 14, 2004 | 11:55 AM
VTECH8TR's Avatar
Originally Posted by Ted B
FWIW, I have similar mods, and I am running 650cc injectors. However, if you're running 95% IDC, while you are running close to static, you probably aren't noting an actual lean condition.
In the case of rraulston's car, he is running factory cams, and even with good tuning would be probably at least some 20whp or so down, which would seem to indicate the injectors shouldn't be causing a serious lean condition. It is impossible? No, but I'm suggesting the fuel pump (or tuning) is the more likely culprit in this case.
Ted,
Gotcha you are correct, i also rewrote my post. I was hitting 95% idc at 6k. I then put in 750cc's and i can easily go up to 7500rpms with 70% idc.
Old Dec 14, 2004 | 12:36 PM
Ted B's Avatar
Which unfortunately, tells me that I will soon need another injector upgrade.
