DO NOT ATTEMPT..fuel pump
Old Dec 16, 2004 | 12:56 AM
EFIxMR's Avatar
to depressurize the lines you unplug the socket that powers the pump, and start the car. the engine will run momentarily then stall. then you proceed to disconnect the lines. to get the black ring off you gotta slide it around and remove it at an angle. at times it seems impossible, but its definately doable and all technique.
Old Dec 16, 2004 | 05:02 AM
smp3000's Avatar
Originally Posted by captain150
We had a good laugh when I made sure it didn't spray into his eye
Dude... What are you really talking about? lol
Old Dec 16, 2004 | 06:19 AM
MitsuJoe's Avatar
yucky....
Anyways the stock fuel regulator can handle the extra flow from the stock to the Walbro setup. I have heard benefits of no more pulling timing on cars in states with 91 to negatives like taking away 5hp on the Dyno in the high rev range. Safety being #1 if you mod your EVO add the fuel pump so your not kicking yourself in the a$$ later.
Old Dec 16, 2004 | 06:26 AM
mifesto's Avatar
Originally Posted by ebbeast2005
Do not try to put your fuel pump in when you have a full tank of gas! You will get gas everywhere and make a big mess. If evom had a jackass of the week it would be me! Anyways, is there any secret trick to getting the black circle piece off that holds the pump in? Its being a pain and for my next attempt i was just curious if theres any trick to it.
i cant believe you attempted this on a full tank of gas hehe... its like adding even more fish to your fishtank before wanting to clean it as for the circle, you gotta attack it at an angle.
Old Dec 16, 2004 | 06:28 AM
blackevoVII's Avatar
sounds like a gay man's fantasy.
Old Dec 16, 2004 | 06:33 AM
mifesto's Avatar
hence your icon, blackevoVII
Old Dec 16, 2004 | 02:06 PM
ebbeast2005's Avatar
I hear ya on the fish tank thing that exactly how it went!!!
Old Dec 16, 2004 | 02:13 PM
justchil's Avatar
There is kind of a trick but I'd have a very hard time explaining it.. mostly just turning it and pulling at a weird angle.
I had like 1/4 tank when I did it.. the fumes really got to me even in a well ventilated area.
Old Dec 16, 2004 | 10:48 PM
EFIxMR's Avatar
i had 3/4 of a tank in mine, not really a problem.
