help with boost guage
Old Dec 15, 2004 | 12:52 PM
RealVibes.net's Avatar
Question help with boost guage
i just installed my boost guage with the help of the write up in the intall forum, my problem is that the guage shows that i am only boosting 14psi tapering to 11psi, what could be the problem??? i checked for leaks and did not find any. any help would be appreciated. ( i bought the car used and the person that sold it back to the dealer had it modded and then changed it back to stock, so now i dont know where to start looking to trouble shoot.
Old Dec 15, 2004 | 12:55 PM
LancerOZ!=Evo's Avatar
Does the car have a MBC on it? If so it may be tuned down for whatever reason the previous owner had. I'd also try another boost guage to make sure it's not broken. Also where are you "T" into to read the boost?
Old Dec 15, 2004 | 01:01 PM
jlanevo8's Avatar
are you seeing 14psi in all the gears? 14 psi is normal in the first 2 gears.
Old Dec 15, 2004 | 01:05 PM
it does not have a boost controller atached to it, i also teed off the fpr line in the pic below
please help
Old Dec 15, 2004 | 01:08 PM
rsboy's Avatar
Make sure you cut the right hoses to tap into. I used one near the intake manifold and "t" connected from there. Also make sure the ends are on there tight. Might need to clamp them securely or zip tie them, which is what i did. If it does have an MBC then you'll need to check that.
good luck!
chrisw's Avatar
your tapping into the fuel presure solinoid. You should move the tap to the BOV line.
Old Dec 15, 2004 | 01:12 PM
mrbkkt1's Avatar
I tapped into the same line. my boost gauge is on turbo timer though (DCII DTT Blitz) when i drive,@ WOT, it boosts heavy- 18-21 psi, then tapers down after about 5500 rpm's. to about 14/15 psi( sorry, it's hard to convert KP to psi while driving.
Not sure about the accuracy of gauge though, so i was looking to get seperate boost gauge anyway. where did you mount yours?
Old Dec 15, 2004 | 01:14 PM
mrbkkt1's Avatar
I wanted to do the same thing, but was worried about "warranty" since mitsu is so touchy about BOV's
Old Dec 15, 2004 | 01:22 PM
mrbkkt1's Avatar
wouldn't want them to say i blew the motor cause bov was malfunctioning cause bov line was tampered w/
Old Dec 15, 2004 | 01:25 PM
donour's Avatar
please help
A lot of us have had no problems using that location. That location will definitely give you a reading straight out of the intake manifold.
d
Old Dec 15, 2004 | 01:27 PM
^^ thats wat i thought, i havent heard of anybody having problems from there, when i had a turbo civic thats where i tapped and it worked perfectly. thats why i am wondering if something was wrong with the car or something.
Old Dec 15, 2004 | 01:28 PM
tokeone's Avatar
thats the line mitsu uses. heres how they tapped the gauge cluster
mrbkkt1's Avatar
i think its normal cause the evo does not boost as much @ high rpms.
what kind of fuel using? (i.e. 91, 92, 93, 94 sorry, i don't know where pembroke pines is)
i found that mixing 100 octane, and 92 octane to get around 94 octane smoothed out my boost curve. i'm guessing that the ecu senses better octane and use diff map.
Old Dec 15, 2004 | 01:29 PM
thats how mine looks
Old Dec 15, 2004 | 01:49 PM
i just took it for another spin to see if it happens in all gears and it surely did, the highest i saw was 13-14 psi tapering to 10-11 psi. i double checked all the hoses,etc and did not find any leaks. i am out of ideas.
