Need a real answer on transmision oil
Old Dec 19, 2004 | 12:35 AM
pharmd98's Avatar
BG synchroshift is great for the transmission. My tranny noise is gone after I started using it.
Old Dec 19, 2004 | 03:44 AM
Cirrusly Evolvd's Avatar
Your service recommendation is written assuming that you will drive the car normally, granny shifting and no hard launches. Many of the tuning shops will recommend some form of Synthetic Syncro Shift oil such as BG or Redline. I would take thier advice over some wrench monkey at the Mitsu service center.
Old Dec 19, 2004 | 03:52 AM
dizzigital's Avatar
Originally Posted by voidhawk
This is from the Redline tech info pages:
MT90 is hard to beat - I've raced the crap out of my Celica's 6sp (road track), and it performed absolutely flawless.
oh reaallly... i've been mis-informed. sorry for posting that about Redline guys.
Old Dec 19, 2004 | 07:05 AM
NOVA EVO's Avatar
Good info...thanks, guys!
Old Dec 19, 2004 | 11:40 AM
YellwTyper's Avatar
tranny=mt-90
Everything else Diaqueen
Old Dec 19, 2004 | 11:50 AM
Ookami's Avatar
BG SyncroShift in the tranmission
DiaQueen LSD Gear Oil in the transfer case and rear diff (bought from Mitsubishi)
I looked into this a few months back... this is the answer.
Old Dec 19, 2004 | 01:30 PM
EVOTEXAS's Avatar
Except that people have had big problems with Syncroshift and its variants. None reported with MT-90. BG, Pennzoil, etc is not the answer.
Old Dec 19, 2004 | 01:39 PM
marksae's Avatar
What kind of problems have people had w/ BG/pennzoil stuff? I know BG is SAE 75, which is too thin for our trannies.
Old Dec 19, 2004 | 01:42 PM
EVOTEXAS's Avatar
Grinding and stuff. I'm too lazy this perfect weather Sunday to pull some links for you. Sorry!!
Quickshift's Avatar
Ive been using gm syncromesh and it works awesome in the tranny, much better than the redline i had in previously (mt-90). Also using diaqueen lsd gear oil in the tc and the rear diff.
Old Dec 19, 2004 | 08:41 PM
voidhawk's Avatar
I just put MT-90 in the (MR) transmission, and so far it seems to work fine. Less grind when cold than the stock stuff. I have not used synchromesh so I can't offer a comparison between those two.
Old Dec 20, 2004 | 06:41 AM
use2vtec's Avatar
can someone post up the price difference between the Redline MT-90 and the GM Synchromesh. Also are there different weights of the GM Synchromesh or do I just go to a GM dealer and ask for "Synchromesh"?
Old Dec 20, 2004 | 06:49 AM
Zeus's Avatar
Do a search on "Syncroshift" and "Syncromesh"... you want the non-synthetic. On one of the threads, all of the above are discussed. The actual GM part number is listed for the Syncromesh. However, it was found that Pennzoil manufactures it, and the Pennzoil stuff you get at Auto Zone (same part number listed on the bottle) is in fact the exact same product. I believe it is about $4.99 a quart there. It was probably the best thing I could have done for the tranny.
Old Dec 20, 2004 | 06:56 AM
EVOTEXAS's Avatar
Syncromesh
http://www.stealth316.com/2-pennzoil-synchromesh.htm
MT-90
Popular in Nissan, Toyota and Mazda manual transmissions and transaxles as well as other selected applications, this is a 75W90 GL-4 Gear Oil that’s slightly heavier than MTL. Provides excellent protection of gears and synchronizers and its balanced slipperiness provides a perfect coefficient of friction, allowing easier shifting.
So basically, the Syncromesh is not GL-4 rated, which is what our car calls for and that is why I use and recommend MT-90.
Old Dec 20, 2004 | 07:33 AM
chrisw's Avatar
Originally Posted by simevo
Redline MT90 = GL4 75W-90 synthetic
wrong... I had some RedLine 75w-90 put in the tranny after a clutch job. Shifted like crap. Switched to RedLine MT-90 and it shifts like butter.
The MT-90 has friction modifiers for the syncros, while the other stuff does not.
