View Poll Results: greddy type s - how many springs ?
stock - two springs
40
34.19%
mod - single spring
77
65.81%
Voters: 117. You may not vote on this poll
poll: greddy type s - two stock springs or single spring mod
^^ its all trial and error.....i currently have the single spring mod done to my car and my idle still dips up and down when i let off the gas and stilll occassionally stalls on me. Ive tried it with 2-3 turns after contact and as much as 7-8 turns and it still does it. Im thinking of going with the Agency Power BOV, which can be 100% recirculated. But if anyone has any suggestions on the Greddy, let me know!
Originally Posted by mobounce
Ok, I'm waiting on my type-s in the mail... whats the true verdict?
With my mods..and running 21-23lbs daily..what to do? Single spring (large one) or what? I'm getting so confused..lol
I just tried the APS BOV, but ended up coming back to the Greddy. The TypeS's driveability is just too hard to beat! The APS is up for sale now.
I have the single spring mod, and had Shiv custom tune me with no mention of a leaking BOV. My power looks pretty on par, as well. The only thing I don't like about the Greddy is the little whistle at part throttle.. oh well.
what is the the lower nipple(smaller) used for anyways. i have my type s recirculated and was wondering why there is a smaller nipple. So do you connect it to the intake pipe or where would you connect it to?
I have never used the second fitting on any of my greddy bovs. I though I remember reading a long time ago that greddy recommends it be open to atmosphere. I have also heard that its good to hook it up to another vacuum source if you are venting the bov to atmosphere.
On a side note, I just tried the single spring mod today after running both springs for a long time. I am not sure what to think. Driveability is perfect, its 110% better. There is no more surging at part throttle or anything, you would think its a non turbo car. Although the only thing that worries me is that the sound is almost gone. It sounds like a really weak bov now, it doesnt have the distinct blow off sound anymore. The reason I am worried about this is that it might be already slightly open which is why it sounds like this. This would be a huge boost leak if it was the case so I am a little worried about it. I might go back to 2 springs to be safe but I hate to because driveability is so good.
Recently installed my Greddy Type-S BOV, with 2 springs on my EVO 7. And turned it about 3-4 turns stiffer than how I received. Reset ECU (disconnected -ve on battery for 30 sec.) car was in a low rpm/stallish mood when idling/stoping for a day then ECU adjusted and car runs perfect, no more low rpm at idle or when coming to a stop.
Had same BOV and 2 spring setup on my EVO 6 as well...no problems with that car either.
Double spring for me!!
I just installed a greddy type S single spring, and the driveability is excellent. However, I like the sound better on the stock BOV, it has a nice whoosh sound where as the type S single spring has a high pitched chirp to it. I guess I'll just have to get used to it. I haven't tried any adjustements yet, so I'm not sure if that will get rid of the chirp.
question i just installed the blow off and i installed it likr the stock blow off. i have it as the needle on top of the blow off is sitting underneth the radiator tube (big black tube) im not sure if thats right, i see in alot of pictures that the vent that you can see the piston is on the intake pointing down im not sure which way is right. please help.thanks
I am running my 03 evo with 2 springs now, tried single spring mod but the valve just kept open and engin strumbled and bogged all the time. I even tightened the screw all the way down but still leak. i thought it could be vacuum leak so checked every pipe, valves, but no leak found. so I just put both springs back and it works fine now,~ Awesome whistle sound~~+ little whoosh sound at end. the car idles little bit unstable in low rpm sometimes(strumbling) but it's not that serious since i am running VTA mod. It was much worse with HKS bov.
why wouldn't single spring mod work for my evo????
