Turbo is cutting, is this why?
Old Dec 19, 2004 | 12:40 AM
skrib's Avatar
alright so I had the blitz boost gauge/turbotimer installed on my evo... when it was first installed it was reading 1.40 (hkpa) which is about 19 psi in psi form. after a week or two, at about 5-6 rpms the car boosts to 1.27 then cuts to .97.... now can this be a problem due to the installed of this boost gauge... is there anyway the installation could of caused this? is it just the turbo? weather possbilities (im in new york)? Please any input would be great since im unsure of the problem at hand right now... thank you
Old Dec 19, 2004 | 01:00 AM
vtluu's Avatar
Check the line that you tapped for the boost gauge--is it leaking? Also check your other hoses (IC, intake) for leaks and make sure your intake (air box) filter isn't clogged up.
Old Dec 19, 2004 | 01:06 AM
mrbkkt1's Avatar
No, that is almost right. evo's don't bost as much in higher rpms. the computer cuts boost down. I have the same gauge.
Old Dec 19, 2004 | 01:27 AM
500whp.com's Avatar
ture, but not all the way to .97, usually if you were boosting at 1.4 it drops to 1.2 but .97...
check the boost settings you have on ur boost controller, that may effect it =)
Old Dec 19, 2004 | 01:30 AM
mrbkkt1's Avatar
N.Y. has good gas right? (93 or above), maybe just the weather. which vacuum line did you tap into, and where did you route it through the firewall?, also, does your car feel any diff from before you put in gauge?
Rych
Sep 17, 2009 12:57 AM
ArchieBabes
May 21, 2008 03:01 PM
Thegame
10
Jul 25, 2007 12:01 PM
IntegxX
12
Apr 10, 2006 04:57 PM
bigboybusa
17
Oct 16, 2005 07:22 AM
