How to lower boost?
Old Dec 19, 2004 | 06:25 PM
herbal77's Avatar
Is there a slight chance it could be my BOV that is leaking at such high boost and thats why it doesnt hold.
Old Dec 19, 2004 | 06:44 PM
herbal77's Avatar
If the MBc is closed its supposed to be Stock, IF I open it a littl efrom there will it add to Stock or will it start from like 11psi
Old Dec 20, 2004 | 12:35 AM
machron1's Avatar
More baseless warnings about lower boost lol. Your car will run fine with minimal boost, but you do need a boost controller.
Old Dec 20, 2004 | 10:21 AM
90GSX-03EVO's Avatar
11 PSI is "stock" when you add an aftermarket boost controler.
Old Dec 20, 2004 | 10:29 AM
herbal77's Avatar
ok, so if I have it closed all the way, it should say 11psi, and it doesnt, it reacts like stock
Old Dec 20, 2004 | 04:23 PM
herbal77's Avatar
I have figured it out , the pros that installed my MBC, were still connecting the selenoid to the equation. So im guessing thats why it tapers, because the ECU is still telling to taper at high rpms.
So I have to disconnect the selenoid two, and plug the 2 holes, but what do I plug them with?
and 'T' the BOV line, and thats when my boost will hold to redline.
Taking selenoid out is the way, but is it safer, will more constant boost mess something up?
thanks for all of your replys, even the bad ones..but hey we are here to learn right
Thanks EvoM.
Old Dec 21, 2004 | 05:16 PM
Thanks EvoM.
You don't have to plug the solenoid, but you can use some vacuum hose end caps that are sold at any auto parts shop (Napa, Auto Zone, Pep Boys, etc.).
Constant boost won't hurt anything, just keep it below 20 PSI. I'd recommend 18 PSI and leave it there until you get more mods that will actually use the higher pressure efficiently.
There really isn't any safety to worry about. The ECU will still be in place to monitor the air flow, and will still initiate fuel cut if it gets too lean.
380EVO
Oct 8, 2016 05:23 PM
6466Animal
Dec 15, 2015 11:32 AM
jameswwt
Feb 13, 2011 05:21 PM
unvyit
E85 / Ethanol
10
Dec 8, 2010 01:06 PM
vegasevo9
Feb 15, 2008 11:07 AM
