Questions on Megan Racing Exhaust
Old Jan 2, 2005 | 07:14 AM
ewoevo's Avatar
I've already done a search and haven't seen this anywhere. I'm not asking about the build quality, or this vs. that. I'm looking to get the downpipe, O2 housing, and high-flow cat from Megan Racing. So, for the guys who have Megan Racing exhausts, will the cel come on with this installed, or will it be good to go? That's all
Old Jan 2, 2005 | 07:33 AM
broeli's Avatar
Yes it will come on. The high flow cat isn't really a high flow cat, it is just a resonator. So basically it is the same as using a test pipe. You can use any of the "fixes" that are cheap and simple to not trigger the cel. Without using any fixes the cel triggered on my Evo after about 40 miles of driving.
Old Jan 2, 2005 | 06:17 PM
ewoevo's Avatar
Thanks for the info. What are some of the "cheap" fixes you're referring to?
Old Jan 2, 2005 | 06:20 PM
tke_413's Avatar
This one's not very cheap, but works
http://lancershop.com/customer/produ...4&cat=9&page=1
Or I've heard you can get a bung to pull the o2 sensor out a little from the gases.
Old Jan 2, 2005 | 08:19 PM
Zeus's Avatar
ewoevo,
I'm running the full Megan turboback exhaust... The best CEL fix for the money is the "spark plug anti-fouler" method. A quick search will show you how to spend the best $5 you ever have to insure no more check engine lights.
or here:https://www.evolutionm.net/forums/sh...ug+anti-fouler
Old Jan 2, 2005 | 09:39 PM
ewoevo's Avatar
Thanks for the info Zeus. Also, did you have any fitment problems with the downpipe or catback?
BTW, Hook em Horns!
Old Jan 2, 2005 | 10:09 PM
plokivos's Avatar
Megans came a long way. When they first came out, they sucked. Everyone immediately knew that they were obvious knock off of Mugen racing name.
But I heard good things about pipings. I mean, it's not that hard to bend pipes on mandrel bend machine and sell it. Nothing mechanical or technical, it's just tube with bents on it.
Old Jan 2, 2005 | 10:10 PM
plokivos's Avatar
BTW, I got my cel light fix with dealer flash.
That or it'll go away in 12 cycles.
Old Jan 2, 2005 | 10:52 PM
Zeus's Avatar
BTW, Hook em Horns!
I had to "re-position" a coupe of rattling heat shields... also, I used the Kart Boy poly exhaust hangers... so there is very little movement in the exhaust... very little. If I had a gripe, it would be that the downpipe uses a flex section over the OE donut gasket. The Helix (nice but pricey), or Espelir (under $200 shipped) downpipes used a one piece mandrel bent pipe with a donut flange for engine movement... better flow.
...a thread with pics of the Espelir: https://www.evolutionm.net/forums/sh...light=downpipe
Old Jan 3, 2005 | 09:17 PM
ewoevo's Avatar
Originally Posted by Zeus
ewoevo,
Zeus,
Thanks for the info and link. That seems very simple to do. Does the Megan downpipe/test pipe come with an O2 bung already installed, or did you have to get one welded in?
Old Jan 4, 2005 | 12:44 AM
broeli's Avatar
The test pipe has an O2 bung.
Old Jan 4, 2005 | 06:50 AM
ewoevo's Avatar
Thanks for the reply Broeli
Old Jan 4, 2005 | 07:35 AM
Zeus's Avatar
No O2 bung in the test pipe... the Second Gen catbacks have the O2 bung in the OE location.
Old Jan 5, 2005 | 04:24 PM
dsm95hybrid's Avatar
Correct, bung located on the mid pipe.
EmirEvoEight
Jun 13, 2014 11:28 AM
evo7_8u
Sep 19, 2012 09:15 AM
Richmond
Nov 3, 2011 05:24 AM
Stage2evo8
63
Jul 1, 2011 08:14 PM
notenoughhp
Mar 20, 2010 08:26 PM
