BIG leak after install of clutch
Old Jan 6, 2005 | 10:39 AM
YEVOVIII's Avatar
Had my RRE Clutch installed about 2 months ago at a good shop here in Texas. They are known for clutch installs in EVOs. Anyway, I noticed right before Christmas that there is a lot of stainage and gooey stuff all over the exhaust pipe area right below the passanger axel(flex pipe area). When the car get hot I can smeel a sweet burning smell and when i touched the stuff on the flexpipe it was reall stick. Kinda looked like oil but it doesnt smell oil. Real sweet smell, sickining. Well now I am getting a poping noise every once in a whil but only when i slow down fast or make a right turn. Does anybody have any idea what this could be?
Remember that it all started after I had my clutch installed.
Thanks
Old Jan 6, 2005 | 10:42 AM
Kaane's Avatar
Tranny fluid leaking from the Axles? Check your seals.
Old Jan 6, 2005 | 02:18 PM
asasin79's Avatar
axle seal or tranny side cv boot
Old Jan 6, 2005 | 02:46 PM
jj_008's Avatar
It could also leak at the TC to tranny connection.
Old Jan 6, 2005 | 02:53 PM
liquidlancer's Avatar
How Gooey Is It? If Its Like Thick Kinda Greese Like Not Oil Its Proly A Torn Cv Boot Or Something And The Clicking Would Be Your Cv Joint Failing
Old Jan 6, 2005 | 02:54 PM
masterevo's Avatar
I would stop driving the car immediately and bring it back to the shop to let them check it out. IF you ended u losing all ur tranny fluids, ur screw! Becareful...
Old Jan 6, 2005 | 02:56 PM
Karash's Avatar
well it could be tranny oil or regular motor oil mixing a bit with that undercarriage wax that is applied from the factory
Old Jan 6, 2005 | 02:57 PM
plokivos's Avatar
hope it's not your battery leaking. that's poision.
find out the source. Just start taking intake, pipings and battery out to see your transmission from above to locate where the leak is coming from.
Before you do that, i would take it back and have them fix it.
Just remember, the leak could come from up top and slowly drip through the pipings and frames.
Old Jan 6, 2005 | 03:00 PM
YEVOVIII's Avatar
I am going back to the shop this weekend to check it out. Is there a place that I can check tranny fluid to see if it is that?
Old Jan 6, 2005 | 03:03 PM
plokivos's Avatar
it's right where the down pipe is to the left. You may have to remove the bottom tray (pia) and look underneath.
Old Jan 6, 2005 | 11:36 PM
o3evo8's Avatar
Veteran: Air Force
You most likely knicked an axle seal. They are about 5 dollars from mitsu They are not that hard to install. I had that happen to my tranny after my clutch install.
Old Jan 7, 2005 | 08:35 AM
superz's Avatar
Go back to the shop. Dont touch anything, let them fix it.
Old Jan 7, 2005 | 09:08 AM
Ev0 1's Avatar
Exactly!
Old Jan 7, 2005 | 10:09 AM
SuperHatch's Avatar
My Guess would have to be a CV boot as well, but I agree with superz 100%
Old Jan 8, 2005 | 01:41 AM
EricJ@AMS's Avatar
After doing a clutch, common places to leak would be, Tcase fill plug not being tight, one of the two O-rings between the tranny and tcase being ripped or gone, there is one large *** one and one little injector sized one. The first time the shop did the shop evos tranny, it was their first one and they ripped one of the o-rings and caused a leak describing yours.
