View Poll Results: Chocolate or Rice?
Chocolate
25.00%
Rice
75.00%
Voters: 4. You may not vote on this poll
Exhaust question
Old Jan 8, 2005 | 10:32 AM
UT_Evo's Avatar
Exhaust question
Ok, A) yes, I know there's a search bar but there's enough nice people that I wont have to use it and I only need a few quick answers B) This may or may not be a really stupid question, but just answer it anyway!
Ok: I just got the full Injen exhaust system with dp (Downpipe, cat-back, and cat-delete) and will be getting it installed today...my question is...do I need to "break it in" or anything? And should I drive easy on it till I get a reflash, or will it be ok? I don't want my engine to blow up cuz it doesn't know what's going on with the new super increased flow
Old Jan 8, 2005 | 10:33 AM
90GSX-03EVO's Avatar
Oh...And you knew that I would be the first to get to respond to this......
Old Jan 8, 2005 | 10:35 AM
UT_Evo's Avatar
You are correct sir , pre-emptive defenses, LoL
Old Jan 8, 2005 | 10:37 AM
KillaSweep's Avatar
You'll be fine...just drive it. It will smell kinda funny for awhile until the muffler breaks in...but you don;t have to go easy on it.
Old Jan 8, 2005 | 10:38 AM
oguratevo's Avatar
Remove your battery terminal for half-hour to reset your system then put it back, then enjoy driving.
Old Jan 8, 2005 | 10:39 AM
UT_Evo's Avatar
What do you have to reset it for? When you reset it does the ECU semi-reflash itself for the new exhaust?
Anyway, you don't need to break in your exhaust, unless you had the catalyc converter's bearings removed. If this happened, you need will need to extrude hone all the internal plumbing on your intake and exhaust track. If you don't have access to an extrude hone facility, then you should sandblast them all. The easiest way to sandblast your intake manifold is to remove the air filter and filter box cover, rev the car to about 5000 RPMs, and then start pouring sand into the stock air box. All the sand will end up comming out the exhaust, so be sure you put a bucket back there to catch it, or just use your cat's litter box to trap the sand.
Happy motoring.
Curt@MrLed's Avatar
Former Vendor
wow
Old Jan 8, 2005 | 10:41 AM
UT_Evo's Avatar
Wow eh? Thanks for that one...
Old Jan 8, 2005 | 10:45 AM
He's whoring............
...........Now, so am I.
Old Jan 8, 2005 | 10:46 AM
xepyt's Avatar
Sigh... good ol' muffler bearings.
Old Jan 8, 2005 | 10:47 AM
UT_Evo's Avatar
Well, if you guys get to *****, so do I
Old Jan 8, 2005 | 10:54 AM
UT_Evo's Avatar
So do I need to reset the system or not? Pretty sure the bearings aren't removed
Old Jan 8, 2005 | 11:04 AM
UT_Evo's Avatar
bump
Old Jan 8, 2005 | 11:10 AM
DaGuL's Avatar
Good call on the bearings...
