HKS rs intake kit question
Old Jan 9, 2005 | 07:34 AM
Derek888's Avatar
I want the HKS racing suction kit but do I need to worry about the MAF? Does it work with the stock one?
Old Jan 9, 2005 | 09:56 AM
2MANYCARS's Avatar
It uses the stock MAF.
Old Jan 9, 2005 | 10:06 AM
Toddevo 8's Avatar
yes, but on the dyno I made no more hp than I did with the stock setup. so I say save your money and use it for other stuff.
Old Jan 9, 2005 | 10:07 AM
housedj's Avatar
Thumbs up
it does use the stock MAF but the most power will be gained by using it w/out the MAF & enclosing it in an airbox like the apexi or hks kansai. if i recall correctly HKS Kansai has gotten around 25-30whp w/ that setup.
Old Jan 9, 2005 | 01:45 PM
GreedMOTO's Avatar
I made 15whp with just the HKS RS intake and SSQ BOV.
Old Jan 9, 2005 | 01:49 PM
housedj's Avatar
the HKS kit also sounds wonderful. makes your stock turbo so loud people will think it's not stock!
just the HKS SPF filter i use fools people, but a certain shop owner thinks i'm losing 20whp for not using the APS CAI that he sells. i laugh at his silliness...
Old Jan 9, 2005 | 05:23 PM
sleet's Avatar
I have it and made power with it aswell, you can use the stock MAF.
Old Jan 9, 2005 | 07:30 PM
Derek888's Avatar
does your car need to be tuned when you install a intake? I was told it is needed.
Old Jan 10, 2005 | 01:47 AM
Evo Police's Avatar
I have heard that some people after installing the HKS RS would get a bogging feeling at times. But then it is advised you get a flash so it will take full use of the intake.
I have heard very good results when you get a flash and intake.
Old Jan 10, 2005 | 04:31 AM
Derek888's Avatar
I thought only when you want real big hp like bigger turbos you dont need the maf. Otherwise the MAF is necessary to retain stock idle?
