how much hp per psi and stock boost quest
Old Jan 9, 2005 | 09:35 AM
RalliArtEvoVIII's Avatar
I'm losing about 4psi due to probably a leak somewhere....I'm relatively stock wit basic mods. How much hp per psi am I losing? And also...what would a stock evo be boostin at 3000rpm WOT?
Ps: off topic but if I cut my antenna will it affect my reception? I wanna cut the entire skinny portion of the antenna off
Old Jan 9, 2005 | 09:40 AM
housedj's Avatar
Wink
i would check all your vacuum lines & stuff to make sure there are none damaged. a stock evo is supposed to be around 19psi at 3500 rpm wot (full boost) tapering to around 16 or so at redline (7000-7500 rpm).
as far as your antenna goes, just get the Perrin shorty antenna. i have 1, it's less than 1/2 the length of stock w/no loss in radio reception.
OneillEvo
Apr 21, 2014 06:52 PM
stageup
West Region
10
Mar 14, 2011 07:32 PM
.MM
Oct 28, 2006 12:23 PM
Evo11V
Apr 18, 2003 03:07 PM
