Anybody with the Apex-I RX6 Turbo kit?
There are a lot of haters on here. Here are some facts.
The IHI turbo that comes w/ the EVO kit is the biggest one available.
Apexi RX6B TCW77L
Power (PS): 560
Ball bearing & water cooled
Comp trim: 55
Comp inducer (mm): 61
Comp Major (mm): 82
Compressor A/R: P21
Comp inlet (mm): 75
Comp. Outlet (mm): 63.5
Turbine Trim: 87
Turbine Exducer (mm): 57
Turbine Major (mm): 61
Housing A/R: P20
Flange Type: RX6B
This turbo is pretty close in size as a GT3040. It should also be noted that the Sparco EVO used the less horsepower TCW76L w/ a P18 housing. At one time it even used the TCW15L which is rated less then the 76L.
The one thing that I don't like about IHI is the lack of compressor and turbine maps. A ported shroud would be nice also. Then a smaller A/R turbine housing could be used.
Apexi RX6B TCW77L
Power (PS): 560
Comp trim: 55
Comp Major (mm): 82
Compressor A/R: P21
Comp inlet (mm): 75
Turbine Trim: 87
Housing A/R: P20
Flange Type: RX6B
Apexi RX6B TCW77L
Power (PS): 560
Comp trim: 55
Comp Major (mm): 82
Compressor A/R: P21
Comp inlet (mm): 75
Turbine Trim: 87
Housing A/R: P20
Flange Type: RX6B
Apexi RX6B TCW77L
Power (PS): 560
Comp trim: 55
Comp Major (mm): 82
Compressor A/R: P21
Comp inlet (mm): 75
Turbine Trim: 87
Housing A/R: P20
Flange Type: RX6B
It is funny you mention the lack of compressor maps. IHI would only provide us maps for some of the product line, not including the RX6B.
Originally Posted by MINES13
Crack open a history book and you will come to find that in fact, the GT series turbochargers are not as new as you may think. A derivative has been in production use since 1989 (Nissan). As with anything technical, the current RX6B and GT series turbo have certainly evolved since they were originally introduced. Also take note that 1980s F1 engine technology is still light years ahead of production car technology today. The only thing the Garrett units have on the IHI pieces are the cost and ease of service. Take them apart and they are about as similar as apples and oranges. I have never seen a turbo with tighter clearances in the bearing journals then an IHI, period. The side effect of IHIs machining and assembly precision is an extremely durable turbo that can and does stand up to the rigors of racing for hours on end. This is why IHI turbochargers dominate to the top levels of European racing. Having played with and rebuilt both I would have to say that the IHI units pound for pound are better judged purely on the metrics of sizing, power band, durability scale. Again, I am not saying Garrett turbochargers are bad or even just ok and the differences I stated for most street cars would be negligible to say the least.
Power Enterprises stainless non-purged-gas welded manifolds and intercooler coolers (ARC) are simply peerless in quality and design, but do not expect them to be cheap.
Ciao , i'm Italian and at first i want say hello to everybody, This is my first reply. I own a evo VII RS with a lot of upgrade including the "isamu" turbo kit, this is my experience: the kit is really bolt on and i haven't problem in istallation all you need is in the kit, the first test was done on the engine 2000 cc but i wasn't really satisfied because the spool start at 4500 g/m , the max power was around 440 cv at 7500 g/m with 2 bar pressure (around 28 PSI). Next step was the stroker 2,3 lt and in this way really change the music ! we spend 2 day with my friend Nocentini ( is the owner of a world rally championship team) at the engine Dyno, was really interesting work on the apex ecu with fc-datalogit, chanche timing on the 272° in/ex hks cams, find the correct fuel pressure and more, the final result was this : 3500 g/m 20 psi 200cv; 4000 g/m 27 psi 360cv; 4500 g/m 30 psi 424 cv and max torque 672 N/m ; 7000 g/m 30 psi 524 cv max power.
All the test runs with fuel 98 oct , we did not rev over 7000 because the linear velocity medium of the piston with the stroker is gone very high + 12 mm.
Finally i don't have experience with other turbo kit but if somebody ask me if i'm satisfied with isamu i say yes! after 1 year i haven't manifold crack ( i'm touching my b****) .
Sorry for my english.
Originally Posted by EFIxMR
Are you sure you know what you're talkin' about here buddy?
MINES13, clearances are a bit of a grey area and within a range, a loose or tight clearance cannot be glorified or condemned. There are relatively loose clearances for maximum power (via reduced friction), and there are relatively tight clearances to maximize longevity. So you cannot draw such a conclusion just because IHI runs the tightest clearances you have ever measured. Designated oil spec also relates to how apt a clearance is.
Tolerances are a different matter altogether, and a zero tolerance is always a target.
I do not think IHI has anything over Garrett. It isn't fair to hold IHI so far over Garrett. Let's not forget Garrett runs / has run, 24 hours of Le Mans LMP and GT classes (including the most winning car in the highest LMP class in the last 5 years), Champ Car, WRC, 80s F1, top level drag.
Hasty condemnation or hasty glorification of a company without detailed technical inspection isn't healthy for a community.
Once upon a time I worked for Power Enterprise and currently maintain a relationship with the company. So yes, I can provide some insight on the subject of IHI turbos and Power Enterprises fabrication and engineering skills.
Are you sure you don't mean back purged welded manifold?
Thanks for the input. Your English is fine, its the numbers that lose me
english to metric. Is the isamu turbo kit the same one we are talking about? Any chance of getting your hands on some good rally parts? pm me, I could use some.
I'll be getting this turbo kit installed and tuned within a month.
I will post up more solid information regarding HP and spoolup. It seems to be a very popular kit in Japan and other areas.
Originally Posted by platinumspecv
I know its kinda pricey but I figured if Apex makes it - it must be great.
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
. You've replied to a post that is over one year old. BTW, I've seen the Apexi kit up close and the fit and quality are amazing. My only concern is the mani, but that can be addressed with a few supports.
