Cone filter with Stock Air Scoop
Originally Posted by marksae
Where are you measuring the air intake temperatures? At the MAF or at the throttle body?
Originally Posted by ThEHiTMaN
For 1 it looks funny to have a scoop running to nothing, second the pins broke and keep breaking, and 3rd to gain access to my DV/ boost controller solenoid I have to take the damn pins out and I always break them. I'm sick of the thing! LOL
The solenoid is actually right next to the water sprayer bottle. But the other night I was checking the size and location of my vac lines because I think the shop that installed the EBC used small vac line. This weekend I plan on replacing the Vac line with something that has a bigger internal diameter. I will live with it off for a while, I'm not sure how much it really helps anyway... I don't notice a thing.
Originally Posted by BJai02
Yes I did. It gets quit hot at idle, but temperature drops quickly once the car is moving, and it is even cooler at boost... I guess the stock intercooler is very efficient with stock turbo.
Back to the topic, I really don't think the scoop is making any difference with open element filter.
If the box were totally enclosed I can see it being somewhat helpful...
In the end, I don't think open element air filters are a worthwhile upgrade from the stock airbox.. Your much better off leaving the stock airbox with a panel filter in place..
FWIW I can measure IAT's easily now that I have an AIT sensor right in the intake tube and no MAF sensor before the turbo.
What I did notice is when the fan kicks in and blows more hot air into the engine bay, the intake air temps climb 15 degrees or more with the open filter.
On an interesting side note, after the intercooler I have a thermocouple mounted, and there was only a 5 degree temp difference with a fresh air source or an under hood source.. the better and cooler the source is obviously worthwhile, but unless you have an airbox getting air exclusively from outside the engine bay, it didn't seem to make much if any difference.
