HP Loss with HF Cat
HP Loss with HF Cat
I asked this over in the DynoFlash forum, but thought I'd ask everyone else also....
How much average do you see HP loss with a HF cat over a testpipe, considering a 3" exhaust from the turbo back?
Anyone have any dyno's? Im debating putting on my 3" HF cat (Magnaflow) to quiet down my car, but I don't want it to feel slow.
BTW, I searched, but couldn't find anything concrete except that DynoFlash said with the 3" UR HF cat, he didn't lose even 1 hp here:
https://www.evolutionm.net/forums/sh...ad.php?t=55371
the UR HF cat uses the magnaflow converter, right? Why did DynoFlash say he gained low end? Backpressure? I thought the testpipe increases everything, even low end.
Thanks for the input.
I dynoed with a high flow cat and without. It was somewhere between 12-15 HP. No other changes. No joke. Sorry I don't have a scanner to post the graphs. Both runs were done at Turbo Trix.
With a Random Tech 3" high flow cat, you can't tell a difference when you switch to the test pipe. I have run with the testpipe on and then switched to the RT cat and couldn't tell a difference at all in just driving the car. In fact, my RT 3" cat still throws a CEL if you dont do the anti spark plug fouler trick. It is very high flow. No loss in boost pressure when switching to the high flow cat either. I am sure there is a measureable difference on the dyno, but the butt dyno will never detect it. My $.02 !!!!
Brian
Brian
I have the RT HF Cat as well, and I also required a single drilled (to 1/2 inch) spark plug anti-fouler to get rid of the CEL.
If you look at it, it looks like a resonator more than a cat, lol. Noticed better spool and top-end with a little more noise after swapping it in. The RT has a CARB sticker, so I would think it could pass emissions, but I haven't had to prove it yet. I think as long as I don't have a CEL they don't even smog it here in MA. Someone please correct me if I'm wrong.
Take care,
FB
Take care,
FB
