Will this (HF CAT) work?
Old Jan 14, 2005 | 07:59 AM
4-BNGR's Avatar
http://www.rpmoutlet.com/powercat.htm
It's un-flanged (11.5" long). Whats the stockers length. I believe this is similar to the Random Tech style HF cat. $135 bucks... Anyone?
4-BNGR
Old Jan 14, 2005 | 08:13 AM
scott88vr6's Avatar
I would spend the extra 15.00 on an Ultimate racing high flow cat. Very nice piecec, bolts up to stock location.
Old Jan 14, 2005 | 08:21 AM
4-BNGR's Avatar
What CFM is the UR HFcat?
Old Jan 14, 2005 | 08:34 AM
scott88vr6's Avatar
Couldn't tell you. All I know id that there was not a noticeble diff. in my high flow compared to the test pipe.
Old Jan 14, 2005 | 08:36 AM
scott88vr6's Avatar
BTW the stock cat is 18.5 inchesd long so you would need to make some flanges.
Old Jan 14, 2005 | 08:44 AM
4-BNGR's Avatar
I can't decide if I want to go with a 2.5" or 3" HFC on my 2.5" turbo back exhaust...
Old Jan 14, 2005 | 09:04 AM
scott88vr6's Avatar
Ultimate racing also has a 2.5 inch high flow for the evo, but if you are eventually going to upgrade to 3 inch, get the 3 inch high flow. Here's a link http://www.ultimate-racing.com/Produ...Downpipe.shtml
Old Jan 14, 2005 | 09:50 AM
jimntjames's Avatar
4-BNGR: I'm going the same route as you. I just bought the UR 2.5 test pipe. I will let you know how that goes if you are interested. It should go on this Monday. I may also pick up a down pipe by then.
Old Jan 14, 2005 | 10:02 AM
Zeus's Avatar
I'd like to see what the rated flow rate is...
